10-30-2017, 18:43 | #1 (permalink) |
Major Poster Join Date: Apr 2010 Location: United Arab Emirates
Member: 1294191 Status: Offline Thanks Meter: 9 | SM-G7102 imei null Done Using file G7102XXUBNG8_OLBBNG3 FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, hold Volume Down + Home + Power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G7102 Software version: 29.5 File analysis... OK Total file size: 0x6D10330C (1745 Mb) Searching USB Flash interface... COM11 detected Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending aboot.mbn... OK Sending sbl1.mbn... OK Sending rpm.mbn... OK Sending tz.mbn... OK Sending sdi.mbn... OK Sending NON-HLOS.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img.ext4... OK Sending persist.img.ext4... OK Sending modem.bin... OK Sending cache.img.ext4... OK Sending hidden.img.ext4... OK Flashing done (time - 00:04:00) Done with Samsung Tool PRO v.29.5 |
The Following User Says Thank You to bel83 For This Useful Post: |
01-09-2018, 06:07 | #2 (permalink) | |
Freak Poster Join Date: Apr 2015 Location: Ilam,Nepal
Member: 2378764 Status: Offline Sonork: I Dont Use !!! Thanks Meter: 60 | For What Your Reporting , Success Or Failed !!! Quote:
