04-08-2015, 07:24 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Inside Samsung Pocket Age: 40
Member: 489331 Status: Offline Thanks Meter: 1,141 | SM-G800H/DS Cert Write Done :) Selected port: COM6 Z3X BOX Serial Port Selected port speed: 115200 Checking certificate file... OK Searching ADB device... OK Reading phone info... Model: SM-G800H Android version: 4.4.2 Product code: Not Active Phone version: G800HXXU1ANGF PDA version: G800HXXU1ANH2 CSC version: G800HOXE1ANG2 IMEI: Unknown Phone S/N: 00000000000 Checking Super user right... true Bypass MSL... OK Checking for compatible phone and cert... OK Writing CERT... OK Checking CERT status... OK Writing Slave CERT... OK Checking Slave CERT status... OK Rebooting phone... OK Done with Samsung Tool v.18.9 |
04-10-2015, 22:57 | #2 (permalink) |
Member: 489331 Status: Offline Thanks Meter: 1,141 | All cert Ask here http://forum.gsmhosting.com/vbb/f453...-post-1855887/ |
The Following User Says Thank You to raulka2003 For This Useful Post: |
05-04-2015, 14:38 | #3 (permalink) |
No Life Poster Join Date: Sep 2011 Location: Dubz
Member: 1651733 Status: Offline Thanks Meter: 21 | which model you using bcoz im tryng on 20.5 nt agree BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Choose diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-G800H Selected port: COM56 SAMSUNG Mobile USB Serial Port , Software version: 20.5 Checking certificate file... error Not supported model (Unknown KEY ID) Done with Samsung Tool v.20.5 |
