09-10-2015, 18:22 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | sm-g900p big security BOG1 Direct Unlock: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button. UNLOCK INSTRUCTIONS: Direct Unlock: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button. UNLOCK INSTRUCTIONS: Direct Unlock: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button. Domestic Unlock: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 5. Press 'Unlock Domestic' button. Operation: Unlock SPRNT Selected model: SM-G900P Selected port: COM10 USB Serial Port Software version: 22.5 Waiting ADB device... Operation: Unlock SPRNT Selected model: SM-G900P Selected port: COM10 USB Serial Port Software version: 22.5 Waiting ADB device... OK Operation: Unlock SPRNT Selected model: SM-G900P Selected port: COM10 USB Serial Port Software version: 22.5 Waiting ADB device... Waiting ADB device... Reading phone info... Model: SM-G900P Android version: 5.0 Product code: Not Active Phone version: G900PVPU3BOG1 PDA version: G900PVPU3BOG1 CSC version: G900PSPT3BOG1 CSC country code: USA CSC sales code: SPR HW version: G900P.04 Phone S/N: 00000000000 Modem board: MSM8974PRO RF cal date: 2014.10.15 IMEI: Initialization AT RIL... OK Unlocking... OK Rebooting phone... OK Reading phone info... Model: SM-G900P Android version: 5.0 Product code: Not Active Phone version: G900PVPU3BOG1 PDA version: G900PVPU3BOG1 CSC version: CSC country code: USA CSC sales code: SPR HW version: G900P.04 Phone S/N: 00000000000 Modem board: MSM8974PRO RF cal date: 2014.10.15 IMEI: Initialization AT RIL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.22.5 |
