04-23-2016, 17:19 | #1 (permalink) |
No Life Poster Join Date: Aug 2014 Location: brazil - brasilia
Member: 2235684 Status: Offline Thanks Meter: 417 | g920i repair drk Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. Operation: Repair DRK Selected model: SM-G920I Software version: 25.2 Checking Recovery file... OK Searching USB Flash Interface... detected COM4 Setup connection... OK Reading data from phone... OK Sending data to phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Android version: 5.1.1 Boot version: G920IDVU3DOJ6 Platform: exynos5 Boot serial: 06157df6bab8b830 Product board: universal7420 Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Checking DRK status... OK Repairing DMVT key... error Rebooting phone... OK Repair DRK done Done with Samsung Tool PRO v.25.2 Now the touch does not add up I have done flash and root and nothing touch only hits wrong after repair rdk |
The Following 2 Users Say Thank You to bruno santana For This Useful Post: |
04-23-2016, 21:31 | #2 (permalink) |
Product Manager Join Date: Nov 2005 Location: WWW
Member: 199768 Status: Offline Thanks Meter: 16,170 | try install new recovery pack or delete old recovery from software folder and repeat repair drk |
The Following User Says Thank You to mk For This Useful Post: |
04-23-2016, 22:37 | #3 (permalink) |
No Life Poster Join Date: Oct 2011 Location: ireland Age: 46
Member: 1670851 Status: Offline Thanks Meter: 267 | this was in another post: To fix digitizer just do this: FIX: Dial *#2663# in the dialer and update the touch screen panel firmware by selecting 'TSP FW update (General)' button. |
The Following 2 Users Say Thank You to krisu0007 For This Useful Post: |
04-25-2016, 20:10 | #13 (permalink) |
Freak Poster Join Date: Jan 2006 Location: MX-KEY is the BEST NOKIA TOOL
Member: 220123 Status: Offline Thanks Meter: 21 | touch problem not stop but like you use touch by meirror if you press left will touch right so any one know how repair touch now i try update downgrade hard resset change efs i make new problem with drk and repair it agian with octupos same promblem touch you press it like mirror |
04-25-2016, 20:32 | #15 (permalink) | |
Member: 2235684 Status: Offline Thanks Meter: 417 | Quote:
