07-24-2015, 21:45 | #1 (permalink) |
Freak Poster Join Date: Oct 2014
Member: 2277857 Status: Offline Thanks Meter: 68 | SM-G910A - Any hope? 1. Will not boot on any version of Lollipop. It gets to Android is Updating and restarts after a couple of seconds. 2. I downgraded to 4.4.4 (N910AATT1ANIE) and the phone boots, but unknown IMEI and baseband. phone is very laggy and restarts after about 30-40 seconds. 3. Phone will not load MTP Driver, and ADB does not see the phone even after USB debugging checked. Therefore I cannot temp root and use bsisco's method. 4. I've tried a couple of repair shops, but they haven't a clue. I can get to download and recovery modes. Any ideas would be greatly appreciated. |
07-24-2015, 22:36 | #2 (permalink) |
Banned Join Date: Nov 2013 Location: Chicago, IL
Member: 2076039 Status: Offline Thanks Meter: 648 | Can you root the phone during the time that its running on 4.4.4? If so there is a fix. If not...there might be a fix through Odin, but I really doubt itll work through download mode. |
07-25-2015, 08:49 | #5 (permalink) |
Freak Poster Join Date: Oct 2012 Location: Viet Nam (VFS)
Member: 1822938 Status: Offline Sonork: 100.1656339 Thanks Meter: 63 | I'm on that situation, and pass that failture of android system because it's has no baseband + imei just do it as fast as you can Pre-req: on 4.4.4 ALL_ATT_N910AUCU1ANIE_N910AATT1ANIE_CL2774708_QB23 73670_REV00_user_low_ship_MULTI_CERT.tar 1. conect to a wifi network (may be you'll receive some reboot while doing these step) 2. Enable debuging option and allow debuging from adb shell 3. Download and install KingRoot-4.0.0.233-release-201505071219_105001.apk (google for this file, must be this file) 4. open and getroot (in this step will fail sometime, but just try again and do as fast as you can) 5 when you see root success, now we go with adb shell you only have 40s or 60s to do with kingroot and work with adb, so just copy and paste this command and paste into comandline and remember grant su request when you type "su" Code: adb shell su dd if=/dev/zero of=/dev/block/mmcblk0p10 dd if=/dev/zero of=/dev/block/mmcblk0p13 dd if=/dev/zero of=/dev/block/mmcblk0p14 dd if=/dev/zero of=/dev/block/mmcblk0p15 dd if=/dev/zero of=/dev/block/mmcblk0p16 This method already tested and success, you can see screenshot here http://vietfones.vn/forum/showthread...lock-repair-ok Last edited by goldenfish125; 07-25-2015 at 08:56. |
