12-03-2015, 18:07 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: yaoundé (av kennedy)
Member: 361348 Status: Offline Thanks Meter: 635 | SM-G9208 root failed FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G9208 Software version: 23.5 File analysis... OK Total file size: 0x01929800 (25 Mb) Searching USB Flash Interface... detected COM17 Setup connection... OK Reading PIT from phone... OK Sending recovery.img... error timeout Done with Samsung Tool PRO v.23.5 after that phone show picture below: G9208 root Pictures, G9208 root Images, G9208 root Photos, G9208 root Videos - Image - TinyPic - Hébergement gratuit d'images, partage de photos et hébergement de vidéos i av tried with odin still same i av flashed 2 time bur still no ok plz how can i root this i av all file twrp-2.8.6.0-zeroflte.img andUPDATE-SuperSU-v2.46 but cant root |
The Following User Says Thank You to hippolyte85 For This Useful Post: |
12-03-2015, 23:30 | #2 (permalink) |
Junior Member Join Date: Aug 2013
Member: 1994901 Status: Offline Thanks Meter: 5 | Hi Did you try with UniKernal ?... if not give a try. Also need help with G9208/G9209/G9200 cert, if you are outside of USA can you please share your G9208 cert ? also i can exchange some of the USA certs with you. |
12-05-2015, 05:12 | #4 (permalink) |
Freak Poster Join Date: Jun 2015 Age: 33
Member: 2418095 Status: Offline Thanks Meter: 125 | G9208 ROOT :http://pan.baidu.com/s/1o6U2jJ8 |
