10-03-2016, 19:56 | #1 (permalink) |
Major Poster Join Date: Jul 2006
Member: 318310 Status: Offline Thanks Meter: 1 | sm-g920f REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Patch Certificate Selected model: SM-G920F Software version: 26.8 Waiting ADB device... OK Reading phone info... Model: SM-G920F Android version: 6.0.1 Product code: SM-G920FZKATPH Phone version: G920FXXU4DPGW PDA version: G920FXXU4DPGW CSC version: G920FOXX4DPH1 CSC country code: portugal CSC sales code: TPH HW version: MP 0.910 Phone SN: R38GA0S29PX Modem board: SHANNON333 RF cal date: 20151022 IMEI: Checking Super user right... true Initialization zTool... OK Running zTool, please wait... error (7.7.8) Current version can not be patched Done with Samsung Tool PRO v.26.8 |
