05-16-2018, 18:15 | #16 (permalink) |
No Life Poster Join Date: Apr 2004 Age: 43
Member: 63646 Status: Offline Sonork: 1670920:45069 Thanks Meter: 23 | After this use z3x 25.5 en select model g920F, unlock , reset frp/ee. It gives erasing ok . phone hangs on startup, no problem. Switch off en put in download mode again, flash stock rom 7.0 and voila phone is working again en samsung accoount/reactivation lock is OFF . thanks |
The Following 7 Users Say Thank You to 45069 For This Useful Post: |
08-22-2018, 17:21 | #17 (permalink) |
Junior Member Join Date: Sep 2015
Member: 2456497 Status: Offline Thanks Meter: 22 | U6 frp For U6, flash combination, go again to download mode, select G531F as a model and unlock FRP Then install normal firmware again as G920. You will see when going to flash normal firmware REACTIVATION LOCK: OFF (if you get an error when flashing firmware, deselect hiddenimg and reflash) |
The Following 22 Users Say Thank You to drageloth For This Useful Post: |
11-02-2018, 16:47 | #20 (permalink) |
Crazy Poster Join Date: Nov 2011 Location: Poland
Member: 1682338 Status: Offline Thanks Meter: 1 | Someone has working link for this combination G920 U6? Every link I found has the same problem "Sorry, you can't view or download this file at this time. Too many users have viewed or downloaded this file recently. Please try accessing the file again later. If the file you are trying to access is particularly large or is shared with many people, it may take up to 24 hours to be able to view or download the file. If you still can't access a file after 24 hours, contact your domain administrator." |
11-02-2018, 18:07 | #21 (permalink) | |
Product Supporter Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Quote:
The Following 3 Users Say Thank You to souma_k For This Useful Post: |
12-02-2018, 15:21 | #22 (permalink) |
No Life Poster Join Date: Sep 2004 Location: South Mrorocco Age: 49
Member: 80599 Status: Offline Sonork: 1621236 Thanks Meter: 281 | Hi to all. Here is COMBINATION_OXA_FA50_G920FXXU6ARC1 https://androidfilehost.com/?fid=746163614322264353 https://androidfilehost.com/?fid=746163614322264353 good luck NB: dont' forget press thanks BOTTON: |
The Following 4 Users Say Thank You to ramoon20 For This Useful Post: |
12-20-2018, 23:33 | #24 (permalink) | |
Freak Poster Join Date: Dec 2002 Age: 50
Member: 19126 Status: Offline Thanks Meter: 35 | Quote:
01-09-2019, 12:19 | #25 (permalink) | |
Junior Member Join Date: Jun 2013
Member: 1969931 Status: Offline Thanks Meter: 3 | Quote:
The Following User Says Thank You to techlogics For This Useful Post: |
03-22-2019, 13:36 | #27 (permalink) | |
Freak Poster Join Date: Sep 2013 Location: INDIA
Member: 2023985 Status: Offline Sonork: WhatsApp Thanks Meter: 314 | Quote:
03-22-2019, 13:47 | #28 (permalink) |
Freak Poster Join Date: Dec 2018 Location: Uzbekistan
Member: 2884960 Status: Offline Thanks Meter: 77 | Try it hush-sms method, All Global Version F,F/DS working, tested 100% Отправлено с моего iPhone используя Tapatalk |
The Following User Says Thank You to Akmalzhon For This Useful Post: |
08-08-2019, 04:13 | #30 (permalink) |
Freak Poster Join Date: Apr 2017 Location: Tajikistan
Member: 2704006 Status: Offline Thanks Meter: 181 | 1 secret in function Z3X box. 1.Flash sboot.bin from combo 2. Do reset frp via UART 3. And after reset don't boot phone. Quickly reboot in download mode and see Reactivation lock is stay OFF Flash TWRP of you want 4. Flash sboot.bin from stock 5. And do factory reset This 100% work. |
The Following 3 Users Say Thank You to bestsoft.tj For This Useful Post: |
