Old 05-08-2018, 13:08   #1 (permalink)
Member: 2713695
Thanks Meter: 2
SM-G920F Remove Samsung Account [Answered]
Hello folks,
i've got a 920F here with samsung reactivation lock. It has G920FXXU6ERC1 firmware.
i've succesfully followed the following steps (except for step 4):
To reset Google account activation or Samsung reactivation lock:
1. Power on the phone in download mode (turn off phone, press vol.down + home + power).
2. Connect the phone to PC with USB cable, install drivers if needed.
3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
4. After phone reboot, go to settings and perform factory reset.
Done with Samsung Tool PRO v.31.5.1
But after rebooting every 'app' has stopped working.
So that means it's impossible to execute step 4. Is there any workaround this?
Old 05-08-2018, 14:06   #2 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 1,073
Originally Posted by rjsalakory View Post
Hello folks,
Bro flash combination sboot and use z3x 25.5 and reset frp ee then log in to samsung with your account and reset from findmyphone and u should be done
Sent from my SM-N950F using Tapatalk
The Following 4 Users Say Thank You to souma_k For This Useful Post:
Old 05-08-2018, 14:14   #3 (permalink)
Member: 2713695
Thanks Meter: 2
thank you for your instructions! so i only have to flash the sboot file from combination file?
Old 05-08-2018, 14:17   #4 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 1,073
thank you for your instructions! so i only have to flash the sboot from combination file?
Yes only sboot to reset
Old 05-08-2018, 14:37   #5 (permalink)
Member: 2713695
Thanks Meter: 2
Operation: Flash
Selected model: SM-G920F
Software version: 25.5
File analysis... OK
Total file size: 0x0018F110 (1 Mb)
Searching USB Flash Interface... detected COM23
Setup connection... OK
Reading PIT from phone... OK
Sending sboot.bin... error timeout
Done with Samsung Tool PRO v.25.5
Did i used the wrong combination firmware sboot file?
Old 05-08-2018, 14:38   #6 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 1,073
Operation: Flash
File analysis... OK
Combination u6??
Old 05-08-2018, 14:43   #7 (permalink)
Member: 2713695
Thanks Meter: 2
Combination u6??
No, i extracted the sboot file from: COMBINATION_OXA_FA50_G920FXXU5APK1_OXA5APK1
There is no U6 within z3x
Old 05-08-2018, 14:45   #8 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 1,073
There is u6 check
Old 05-08-2018, 14:52   #9 (permalink)
Member: 2713695
Thanks Meter: 2
There is u6 check
https://imgur.com/a/dMeilu8
Old 05-08-2018, 14:54   #10 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 1,073
Check in shell you should find when i reach home i will send u file
Old 05-08-2018, 15:28   #11 (permalink)
Member: 2562594
Thanks Meter: 45
Combination G920FXXU6ARC1
Download Here Friend Enjoy
The Following 10 Users Say Thank You to armanking0077 For This Useful Post:
Old 05-08-2018, 15:31   #12 (permalink)
Member: 2713695
Thanks Meter: 2
Was allready searching the web but couldnt find it. You the MVP, thank you!!
The Following User Says Thank You to rjsalakory For This Useful Post:
Old 05-08-2018, 15:33   #13 (permalink)
Member: 2562594
Thanks Meter: 45
Dear Bro Use Thanks Button Dont Say Thanks
The Following 3 Users Say Thank You to armanking0077 For This Useful Post:
Old 05-08-2018, 15:52   #14 (permalink)
Member: 2713695
Thanks Meter: 2
sorry about that, thanked you again
unfortionatly im stuck with the following:
Searching Samsung USB Flash Interface... detected COM23
Searching FRP lock... OK
Erasing FRP... OK
Searching Reactivation lock... OK
Erasing Reactivation lock... OK
Searching EE lock... OK
Erasing EE lock... OK
Reset done
https://imgur.com/a/hENCR9F
what do i have to do now?
Old 05-08-2018, 16:17   #15 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 1,073
Erasing FRP... OK
Reset done
Flash sboot from stock rom
The Following User Says Thank You to souma_k For This Useful Post:
Page generated in 2.94864 seconds with 7 queries
