Old 05-16-2018, 18:15   #16 (permalink)
Member: 63646
Sonork: 1670920:45069
Thanks Meter: 23
Thanks this is 100% working solution . I have S6 G920F 7.0 with reactivation lock on. I flashed s-boot from this combination file. After that phone hangs on startup, no problem, switch phone off en put in download mode again.
After this use z3x 25.5 en select model g920F, unlock , reset frp/ee.
It gives erasing ok . phone hangs on startup, no problem. Switch off en put in download mode again, flash stock rom 7.0 and voila phone is working again en samsung accoount/reactivation lock is OFF . thanks
The Following 7 Users Say Thank You to 45069 For This Useful Post:
Old 08-22-2018, 17:21   #17 (permalink)
Member: 2456497
Thanks Meter: 22
U6 frp
For U6, flash combination, go again to download mode, select G531F as a model and unlock FRP
Then install normal firmware again as G920. You will see when going to flash normal firmware REACTIVATION LOCK: OFF
(if you get an error when flashing firmware, deselect hiddenimg and reflash)
The Following 22 Users Say Thank You to drageloth For This Useful Post:
Old 10-21-2018, 14:33   #18 (permalink)
Hafiz ArslanAli's Avatar
Member: 820592
Sonork: 100.1590378
Thanks Meter: 327
Originally Posted by armanking0077 View Post
Combination G920FXXU6ARC1
Download Here Friend Enjoy
Link is deleted........... please upload new link
Old 10-21-2018, 14:50   #19 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 1,273
https://shell.boxwares.com/Download.aspx?L=5776
Old 11-02-2018, 16:47   #20 (permalink)
Crazy Poster
Member: 1682338
Someone has working link for this combination G920 U6?
Every link I found has the same problem
"Sorry, you can't view or download this file at this time.
Too many users have viewed or downloaded this file recently. Please try accessing the file again later. If the file you are trying to access is particularly large or is shared with many people, it may take up to 24 hours to be able to view or download the file. If you still can't access a file after 24 hours, contact your domain administrator."
Old 11-02-2018, 18:07   #21 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 1,273
https://drive.google.com/file/d/1hJr...w?usp=drivesdk
The Following 3 Users Say Thank You to souma_k For This Useful Post:
Old 12-02-2018, 15:21   #22 (permalink)
Member: 80599
Sonork: 1621236
Thanks Meter: 280
Hi to all.
Here is COMBINATION_OXA_FA50_G920FXXU6ARC1
https://androidfilehost.com/?fid=746163614322264353
good luck
NB: dont' forget press thanks BOTTON:
The Following 4 Users Say Thank You to ramoon20 For This Useful Post:
Old 12-17-2018, 16:32   #23 (permalink)
Member: 809685
Sonork: prince2parag
thanks ... this method worked like a charm ,
thanks once again
Old 12-20-2018, 23:33   #24 (permalink)
Member: 19126
Thanks Meter: 35
or if you flashed with hidden.img receiving error, start download mode and check only modem.img to be flashed, phone will boot - looooooong boot on Samsung, and then will start upgrading firmware
Old 01-09-2019, 12:19   #25 (permalink)
Member: 1969931
Thanks Meter: 3
your method worked like a charm every other method was resulting in an unstable firmware thanks a lot mate .
The Following User Says Thank You to techlogics For This Useful Post:
Old 03-09-2019, 13:10   #26 (permalink)
Member: 1832186
Sonork: 100.1678084
Thanks Meter: 72
i have success this method
http://www.youtube.com/watch?v=F6HZV65NTZc
Old 03-22-2019, 13:36   #27 (permalink)
Member: 2023985
Sonork: WhatsApp
Thanks Meter: 314
thanks alot worked for me
Old 03-22-2019, 13:47   #28 (permalink)
Member: 2884960
Thanks Meter: 77
Try it hush-sms method, All Global Version F,F/DS working, tested 100%
Отправлено с моего iPhone используя Tapatalk
The Following User Says Thank You to Akmalzhon For This Useful Post:
Old 08-07-2019, 17:32   #29 (permalink)
Registered User
Member: 197113
Thanks Meter: 11
thanks once again
Old 08-08-2019, 04:13   #30 (permalink)
Member: 2704006
Thanks Meter: 181
1 secret in function Z3X box.
1.Flash sboot.bin from combo
2. Do reset frp via UART
3. And after reset don't boot phone. Quickly reboot in download mode and see
Reactivation lock is stay OFF
Flash TWRP of you want
4. Flash sboot.bin from stock
5. And do factory reset
This 100% work.
The Following 3 Users Say Thank You to bestsoft.tj For This Useful Post:
Page generated in 0.21449 seconds with 8 queries
