06-30-2015, 19:39 | #1 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 51
Member: 3617 Status: Offline Thanks Meter: 579 | SM-G920T 5.1.1 is possible to unlock with Z3x??? today i rooted and unlock with Z3x Sm-G920T version 5.0.2 i try to do the same thing with version 5.1.1 and with the same root now phopne stuck in logo with a red message RECOVERY IS NOT SEANDROID ENFORCING what can i do any help |
06-30-2015, 23:58 | #9 (permalink) |
Banned Join Date: Nov 2013 Location: Chicago, IL
Member: 2076039 Status: Offline Thanks Meter: 648 | Holy **** there's so much misinformation in this single thread. First off you CANNOT DOWNGRADE FROM 5.1.1. Stop trying to soft brick people's phones. Secondly, this is not an issue with the reactivation lock. This is a security measure by Samsung to stop CF-root. Thirdly, I'm pretty sure you cannot root with pingpong root for 5.1.1. Search around. It's been done on 5.1.1. With that said, you're not going to be able to repair the IMEI (unless you have the "patch" floating around). Search, search, and then search some more. I guarantee you, if you don't do your research you will most likely have a soft-brick that is difficult to recover from. |
The Following 3 Users Say Thank You to ecs87 For This Useful Post: |
07-01-2015, 01:56 | #11 (permalink) | |
No Life Poster Join Date: Oct 2014 Location: Guatemala
Member: 2273678 Status: Offline Thanks Meter: 293 | Quote:
The Following User Says Thank You to F_X For This Useful Post: |
07-01-2015, 08:16 | #12 (permalink) |
Freak Poster Join Date: Sep 2011
Member: 1659385 Status: Offline Sonork: 100.1678591 Thanks Meter: 115 | Search for this: Galaxy S6 5.1.1 Root (All Variants).zip worked for me on same model running 5.1.1... It trips Knox but you get root. I assume you can flash back to stock once unlocked since Z3X unlock should be permanent. Last edited by jcdes; 07-01-2015 at 08:23. |
07-07-2015, 09:36 | #13 (permalink) |
Freak Poster Join Date: Apr 2015 Age: 33
Member: 2372105 Status: Offline Sonork: 100.1667845 Thanks Meter: 61 | I see people still unlock G920T normal, and it normally root. Is there they did not share the Root method ..... if so, we can not unlock 5.1.1 G920T |
