01-13-2016, 19:18 | #1 (permalink) |
Freak Poster Join Date: Jun 2010 Location: ON Maind
Member: 1326581 Status: Offline Sonork: (((NAEEM))) Thanks Meter: 52 | SM-G920V after unlock no sim show NO SIM NO SERVICE ???????????????????? .................................................. ....... Operation: Unlock Selected model: SM-G920V Selected port: COM6 SAMSUNG Mobile USB Serial Port Software version: 24.1 Reading phone info... Reading IMEI... OK IMEI: 990004863333104 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.24.1 .................................................. ...................... |
The Following User Says Thank You to (((NAEEM))) For This Useful Post: |
09-18-2019, 17:51 | #10 (permalink) |
Freak Poster Join Date: Aug 2009 Location: Zanzibar Tanzania
Member: 1091079 Status: Offline Thanks Meter: 13 | REPAIR INSTRUCTIONS: Try different algorithm types if you got errors during procedures (Old and New securities) Activate Diagnostic Port: 1. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Select device in ADB settings. 2. Press 'Activate Diag' button. Reset EFS, Disable Factory Mode: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. 6. If you have yellow table on your device screen, then press 'Disable Factory Mode' button. Wipe EFS/NVM: If you have 'IMEI null/null' or 'Phone baseband unknown' errors, Then you can try to repair this errors with this function. Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. To use 'Auto backup/restore QCN' function (recommended): Type *#0808# and select 'DM+MODEM+ADB'. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function. Or you can disable this function and use ADB only. 4. Connect the phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings if 'Auto backup/restore QCN' is not skipped. 6. Select device in ADB settings. 7. Press 'Wipe EFS/NVM' button. Operation: Unlock Selected model: SM-G920V Selected port: COM65 SAMSUNG Mobile USB Serial Port Software version: 24.1 Reading phone info... Reading IMEI... OK IMEI: 358880071173911 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.24.1 |
