07-25-2015, 23:38 | #1 (permalink) |
Freak Poster Join Date: Jun 2007
Member: 527921 Status: Offline Thanks Meter: 23 | SM -G925 Fails to Unlock Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-G925T Software version: 21.8 Waiting ADB device... OK Reading phone info... Model: SM-G925T Android version: 5.0.2 Product code: Phone version: G925TUVU1AOCG PDA version: G925TUVU1AOCG CSC version: G925TTMB1AOCG CSC country code: USA CSC sales code: TMB HW version: Phone S/N: 00000000000 Modem board: SHANNON333 RF cal date: IMEI: Checking Super user right... true Reading nv data... OK Checking magic... OK Initialization AT RIL... OK Sending request to server... OK Calculating... error Mismatch decrypted and readed data Done with Samsung Tool PRO v.21.8 Other users are encountering same issue also. G925T Read Cert + Unlock Fail Any more feedbackback or potential solution would be helpful. |
07-26-2015, 00:08 | #2 (permalink) |
Member: 527921 Status: Offline Thanks Meter: 23 | Constant Same ISSUE ---- Any solution or suggestion UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-G925T Software version: 21.8 Waiting ADB device... OK Reading phone info... Model: SM-G925T Android version: 5.0.2 Product code: Phone version: G925TUVU1AOCG PDA version: G925TUVU1AOCG CSC version: G925TTMB1AOCG CSC country code: USA CSC sales code: TMB HW version: Phone S/N: 00000000000 Modem board: SHANNON333 RF cal date: IMEI: Checking Super user right... true Reading nv data... OK Checking magic... OK Initialization AT RIL... OK Sending request to server... OK Calculating... error Mismatch decrypted and readed data Done with Samsung Tool PRO v.21.8 |
