10-27-2015, 18:39 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: yaoundé (av kennedy)
Member: 361348 Status: Offline Thanks Meter: 635 | sm-g925f dead FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G925F Software version: 23.1 File analysis... OK Total file size: 0xE0BEB390 (3595 Mb) Searching USB Flash Interface... detected COM17 Setup connection... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending cm.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending cache.img... OK Sending hidden.img... OK Sending modem.bin... OK Flashing done (time - 00:03:52) Done with Samsung Tool PRO v.23.1 how can i solved this plz.... |
The Following User Says Thank You to hippolyte85 For This Useful Post: |
