sm-g925f multiple problem. [Solved] 1 no servive 2 unable toot firmware 3 ime no on back is diffrent 4 back stiker model show sm-g925i Waiting ADB device... OK Reading phone info... Model: SM-G925F Android version: 6.0.1 PDA version: G925FXXU5DQAE CSC version: G925FOXE5DQA3 Phone version: G925FXXU5DPL3 Product code: SM-G925FZKASER CSC country code: Russia CSC sales code: SER Phone SN: R58G61FQBWB IMEI: 359523067818342 HW version: MP 0.700 RF cal date: 20150618 Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2017-01-01 Boot Warranty bit: 1 Checking Super user right... false Root your phone manually and then repeat Done with Samsung Tool PRO v.33.5 |
Hi, please use combo file for that binary... then use stock rom for that binary version G925I, then make require operations... you wil be ok... Best Regards Z3X-Team |
diffrent combination file try many error now write 7.0 REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Operation: Repair Selected model: SM-G925F Software version: 33.5 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: SM-G925F Android version: 7.0 PDA version: G925FXXU6ERF5 CSC version: G925FVIR6ERF1 Phone version: G925FXXU6ERF6 Product code: SM-G925FZKASER CSC country code: UK CSC sales code: VIR Phone SN: R58G61FQBWB IMEI: 359523067818342 HW version: MP 0.700 RF cal date: 20150618 Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2018-06-01 Boot Warranty bit: 1 Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... OK HWID: 88 D9 4D 2C E7 04 00 00 00 00 00 00 00 00 00 00 Calculating... OK Repairing... OK Writing NV data... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.33.5 |
cert repaire REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Operation: Patch Certificate Selected model: SM-G925F Software version: 33.5 Waiting ADB device... OK Reading phone info... Model: SM-G925F Android version: 7.0 PDA version: G925FXXU6ERF5 CSC version: G925FVIR6ERF1 Phone version: G925FXXU6ERF6 Product code: SM-G925FZKASER CSC country code: UK CSC sales code: VIR Phone SN: R58G61FQBWB IMEI: 358344086190923 HW version: MP 0.700 RF cal date: 20150618 Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2018-06-01 Boot Warranty bit: 1 Checking Super user right... true Initialization zTool... OK Running zTool, please wait... OK Reading modem... OK Patching modem... OK Writing modem... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.33.5 |
