Old 08-09-2018, 16:51   #1 (permalink)
DIN231080's Avatar
Member: 523792
Thanks Meter: 94
sm-g925f multiple problem. [Solved]
1 no servive
2 unable toot firmware
3 ime no on back is diffrent
4 back stiker model show sm-g925i
Waiting ADB device... OK
Reading phone info...
Model: SM-G925F
Android version: 6.0.1
PDA version: G925FXXU5DQAE
CSC version: G925FOXE5DQA3
Phone version: G925FXXU5DPL3
Product code: SM-G925FZKASER
CSC country code: Russia
CSC sales code: SER
Phone SN: R58G61FQBWB
IMEI: 359523067818342
HW version: MP 0.700
RF cal date: 20150618
Chip name: EXYNOS7420
Modem board: SHANNON333
Security patch: 2017-01-01
Boot Warranty bit: 1
Checking Super user right... false
Root your phone manually and then repeat
Done with Samsung Tool PRO v.33.5
Old 08-09-2018, 19:42   #2 (permalink)
Z3X
Member: 706257
Thanks Meter: 54
Hi, please use combo file for that binary... then use stock rom for that binary version G925I, then make require operations... you wil be ok...
Best Regards
Z3X-Team
Old 08-11-2018, 08:24   #3 (permalink)
DIN231080's Avatar
Member: 523792
Thanks Meter: 94
diffrent combination file try many error now write 7.0
REPAIR INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Fill values what you need to repair.
6. Press 'Repair' button.
7. Press 'Patch Certificate' if you have network problem after repairing.
7. Press 'Reset EFS' if you need to reset it.
Be carefully, do not perform this without necessity. Backup will be created automatically.
Operation: Repair
Selected model: SM-G925F
Software version: 33.5
If you are looking for 'Repair Network' function then you should use 'Patch Certificate'
Model: SM-G925F
Android version: 7.0
PDA version: G925FXXU6ERF5
CSC version: G925FVIR6ERF1
Phone version: G925FXXU6ERF6
CSC country code: UK
CSC sales code: VIR
Security patch: 2018-06-01
Checking Super user right... true
Reading NV data... OK
Checking NV data... OK
Initialization zTool... OK
Running zTool, please wait... OK
HWID: 88 D9 4D 2C E7 04 00 00 00 00 00 00 00 00 00 00
Calculating... OK
Repairing... OK
Writing NV data... OK
Rebooting phone... OK
Repair done
Old 08-11-2018, 08:36   #4 (permalink)
DIN231080's Avatar
Member: 523792
Thanks Meter: 94
cert repaire
Operation: Patch Certificate
Model: SM-G925F
CSC sales code: VIR
IMEI: 358344086190923
Reading modem... OK
Patching modem... OK
Writing modem... OK
Patching CERT check... done
Page generated in 0.34566 seconds with 7 queries
