09-24-2017, 20:47 | #1 (permalink) |
Junior Member Join Date: Sep 2017
Member: 2761129 Status: Offline Thanks Meter: 0 | SM-G925F S6 Edge No Modem Found I have been at this for weeks and decided to see if I could get direct help. G925F I'm on Android 7.0 at present But have tried downgrading to 6.01 with similar results. I have also tried flashing lots of different modems and different versions of Samsung Pro Tool Now im back on Android 7.0 via 4 flash recovery files. Problem is No Baseband/No Imei/No Sim detect and Z3x is detecting no modem??? I'm starting to think this could be hardware related. Please see logs. Thanks for any help.... Operation: Info Selected model: SM-G925F Software version: 29.3.1 Searching Samsung modem... not found Done with Samsung Tool PRO v.29.3.1 Operation: Repair Selected model: SM-G925F Software version: 29.3.1 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: SM-G925F Android version: 7.0 Product code: Phone version: PDA version: G925FXXU5EQD7 CSC version: G925FMET5EQC4 CSC country code: Ireland CSC sales code: MET HW version: Phone SN: 00000000000 Chip name: EXYNOS7420 Modem board: Security patch: 2017-04-01 RF cal date: IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Can not detected modem type Done with Samsung Tool PRO v.29.3.1 |
09-24-2017, 21:07 | #3 (permalink) | |
Junior Member Join Date: Jun 2010
Member: 1331962 Status: Offline Thanks Meter: 3 | Quote:
Sent from my Pixel using Tapatalk | |
09-24-2017, 21:39 | #5 (permalink) | |
The Following User Says Thank You to azzzel For This Useful Post: |
09-24-2017, 21:41 | #6 (permalink) | |
https://onedrive.live.com/?authkey=!...&action=locate Sent from my Pixel using Tapatalk | |
09-24-2017, 22:38 | #9 (permalink) |
Member: 2761129 Status: Offline Thanks Meter: 0 | Thanks Guys. Tried the 2 modems same deal. Ive downgraded to 6.01 and flashed modem in the past also. Regards repairing the EFS how would I go about that??? I'm on 7.0 and I have no EFS Backup for this phone. Would a corrupt EFS stop Samsung pro from reading the Modem Board id??? Thanks |
09-24-2017, 23:21 | #11 (permalink) |
Member: 2761129 Status: Offline Thanks Meter: 0 | Operation: Read CERT Selected model: SM-G925F Software version: 29.4 Waiting ADB device... OK Reading phone info... Model: SM-G925F Android version: 7.0 Product code: Phone version: PDA version: G925FXXU5EQD7 CSC version: CSC country code: CSC sales code: HW version: Phone SN: RF8H116QB7D Chip name: EXYNOS7420 Modem board: Security patch: 2017-04-01 RF cal date: IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... error Security damaged (4 13) Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.29.4 So just flashed EFS still same problems no Baseband/IMEI/Modem detected Also getting Security Damaged now as above????? Thanks |
09-24-2017, 23:36 | #12 (permalink) |
No Life Poster Join Date: May 2016 Location: Madina, Accra, GHANA
Member: 2575234 Status: Offline Thanks Meter: 1,134 | Your problem is hardware issue. You can write back your default efs in this location C:\Program Files\Z3X\Samsung\SamsungToolPRO\backup\EFS. |
The Following User Says Thank You to Kwesi_Roy_GH For This Useful Post: |
