Sm-g925t pk5 build BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Write CERT' to restore certificates. 7. Press 'Write NV DATA' if you need to restore NV backup. Read certificate operation: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read CERT' button to read certificates. Operation: Write CERT Selected model: SM-G925T Software version: 27.9 Waiting ADB device... Ok Reading phone info... Model: SM-G925T Android version: 6.0.1 Product code: Phone version: G925TUVU5EPJ1 PDA version: G925TUVU5EPK5 CSC version: G925TTMB5EPK5 CSC country code: USA CSC sales code: TMB HW version: Phone SN: R58G40WH8YN Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2016-11-01 RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Initialization zTool... Ok Running zTool, please wait... Ok HWID: 08 1F 07 AF 8C 06 00 00 00 00 00 00 00 00 00 00 Calculating... Ok Initialization AT RIL... AT RIL stopped, restarting... Ok Checking for compatible phone and cert Phone KEY ID: 0346 Checking certificate file... Ok KEY ID: 0346 Crypting CERT 1... Ok Writing NV data... Ok Rebooting phone... Ok Done with Samsung Tool PRO v.27.9 |
