12-12-2018, 16:14 | #1 (permalink) |
Freak Poster Join Date: Mar 2017
Member: 2693973 Status: Offline Thanks Meter: 10 | SM-G925t securite damaged [Answered] BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Write CERT' to restore certificates. 7. Press 'Write NV DATA' if you need to restore NV backup. Read certificate operation: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read CERT' button to read certificates. Read certificate via diagnostic port: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read CERT DIAG' button to read certificates. Operation: Write CERT Selected model: SM-G925T Software version: 34.5 Waiting ADB device... OK Reading phone info... Model: SM-G925T Android version: 6.0.1 PDA version: G925TUVU5EPK5 CSC version: G925TTMB5EPK5 Phone version: G925TUVU5EPK5 Product code: CSC country code: USA CSC sales code: TMB Phone SN: IMEI: 350000000000006 HW version: RF cal date: Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2016-11-01 Boot Warranty bit: 1 SIM State: NOT_READY Checking Super user right... true Reading NV data... OK Checking NV data... error Security damaged (1) Done with Samsung Tool PRO v.34.5 |
