10-18-2017, 19:39 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | SM-G925T unlock done latest build New Securiry Type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. 6. Press 'Read codes' button and select 'Read codes New' to read security codes. Old Securiry Type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. 5. Press 'Read codes' button and select 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. To reset Google account activation lock with UART cable: 1. Phone must be powered off 2. Connect the phone to UART cable. 3. Select correct COM port in port settings. 4. Press 'Reset FRP UFS' and follow the instructions in program. Operation: Unlock Selected model: SM-G925T Selected port: COM651 SAMSUNG Mobile USB Serial Port Software version: 29.5 Waiting ADB device... OK Reading phone info... Model: SM-G925T Android version: 7.0 Product code: SM-G925TZWATMB Phone version: G925TUVU5FQG3 PDA version: G925TUVU5FQG3 CSC version: G925TTMB5FQG3 CSC country code: USA CSC sales code: TMB HW version: REV0.2 Phone SN: R58G5189R1P Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2017-07-01 RF cal date: 20150821 IMEI: 359146060763255 Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... OK HWID: 48 A8 5D ED F6 06 00 00 00 00 00 00 00 00 00 00 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.5 |
The Following 3 Users Say Thank You to ghacks For This Useful Post: |
