04-06-2017, 00:19 | #1 (permalink) |
Freak Poster Join Date: May 2009 Location: san fernando city la union
Member: 1028799 Status: Offline Thanks Meter: 49 | sm-g925w8 6.0.1 unlocked ZiiFile File Sharing - Easy way to share your files UNLOCK INSTRUCTIONS: New Securiry Type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. 6. Press 'Read codes' button and select 'Read codes New' to read security codes. Old Securiry Type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. 5. Press 'Read codes' button and select 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Read Codes Selected model: SM-G925W8 Software version: 28.0 Waiting ADB device... Ok Reading phone info... Model: SM-G925W8 Android version: 6.0.1 Product code: SM-G925WZWAGLW Phone version: G925W8VLU5CPK4 PDA version: G925W8VLU5CPK4 CSC version: G925W8OYA5CPK4 CSC country code: Canada CSC sales code: GLW HW version: REV0.1 Phone SN: R58G50K74SD Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2016-11-01 RF cal date: 20150509 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Initialization zTool... Ok Running zTool, please wait... Ok HWID: 88 4C BF 0E 55 07 00 00 00 00 00 00 00 00 00 00 Calculating... Ok Checking hash file... Ok Please wait, calculating codes... OK (time - 00:00:13) Freeze code: 72726803 NET lock: 38207249 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.28.0 |
