Old 02-14-2019, 15:19   #1 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 634
Sm-g925w8 imei: 350000000000006
REPAIR INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Fill values what you need to repair.
6. Press 'Repair' button.
7. Press 'Patch Certificate' if you have network problem after repairing.
7. Press 'Reset EFS' if you need to reset it.
Be carefully, do not perform this without necessity. Backup will be created automatically.
Operation: Repair
Selected model: SM-G925W8
Software version: 34.8
If you are looking for 'Repair Network' function then you should use 'Patch Certificate'
Waiting ADB device... OK
Reading phone info...
Model: SM-G925W8
Android version: 7.0
PDA version: G925W8VLU6DRF1
CSC version: G925W8OYA6DRF1
Phone version: G925W8VLU6DRF1
Product code:
CSC country code: Canada
CSC sales code: RWC
Phone SN:
IMEI: 350000000000006
HW version:
RF cal date:
Chip name: EXYNOS7420
Modem board: SHANNON333
Security patch: 2018-06-01
Boot Warranty bit: 1
SIM State: ABSENT
Checking Super user right... true
Reading NV data... OK
Checking NV data... error
Security damaged (1)
Done with Samsung Tool PRO v.34.8
Old 02-14-2019, 15:55   #2 (permalink)
Member: 2613252
Thanks Meter: 898
Hello, if you read the log of z3x software you have the security damaged, to repair the security you have to write the file nv data for g925w8 and then make the patch cert
Here you can read the post
G925w8 imei repair error
Old 02-15-2019, 05:15   #3 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 634
after write baseband unknow what i do ?
Old 02-15-2019, 15:20   #4 (permalink)
Member: 772728
Thanks Meter: 142
my brother
flash the phone last virsion
after flash will back basband
and see the imei is 350000000
just write nv date and write imei and patch network
Page generated in 0.23741 seconds with 7 queries
