Old 12-06-2017, 10:22   #1 (permalink)
Member: 2537939
Sonork: 100.1670350
Thanks Meter: 708
sm-g928 6.0.1 without root unlock done :P
UNLOCK INSTRUCTIONS:
To unlock NEW security type:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock' button and select 'New Unlock' for direct unlock.
To unlock OLD security type:
2. Connect the phone to PC with USB cable.
3. Check Samsung modem in device manager, install drivers if needed.
4. Press 'Unlock' button and select 'Unlock' for direct unlock.
To read security codes (all security types):
4. Press 'Read codes' button to read security codes.
To reset Google account activation lock:
1. ADB must be activated in any way (you can flash sBoot from combination firmware,
make sure, that you are not upgrade sBoot).
2. Connect the phone to PC with USB cable, install drivers if needed.
3. Select device in ADB settings.
4. Press 'Reset FRP' and follow the instructions in program.
5. When process done, press 'Back' on phone and perform factory reset from phone settings.
To reset Google account activation or Samsung reactivation lock:
1. Power on the phone in download mode (turn off phone, press vol.down + home + power).
3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
4. After phone reboot, go to settings and perform factory reset.
To reset Google account activation lock with UART cable:
1. Phone must be powered off
2. Connect the phone to UART cable.
3. Select correct COM port in port settings.
4. Press 'Reset FRP UFS' and follow the instructions in program.
Operation: Unlock
Selected model: SM-G928A
Selected port: COM1210 SAMSUNG Mobile USB Serial Port
Software version: 29.6
Searching Samsung modem... detected COM1209
Reading phone info... OK
Model: SM-G928A
AP version: G928AUCS4CPK5
CSC version: G928AUCS4CPK5
CP version: G928AUCU4APK1
Product code: SM-G928AZKEPRT
Phone SN: R38G70AH4JW
Unique number: 06157DF69A237606
Reading IMEI... OK
IMEI: 3535130@@@@@@@@ (SIGN: OK)
Reading data from phone... OK
Unlocking... OK
Rebooting phone... OK
Unlock done
Done with Samsung Tool PRO v.29.6
The Following User Says Thank You to lerner_ For This Useful Post:
Page generated in 0.11292 seconds with 8 queries
