05-03-2017, 03:50 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | Sm-g928a unlock done by z3x latest build To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Read Codes Selected model: SM-G928A Software version: 28.1 Searching Samsung modem... detected COM82 Reading phone info... Ok Model: SM-G928A AP version: G928AUCS4CQB2 CSC version: G928AATT4CQB2 CP version: G928AXXXXXXXXX Product code: SM2G928AZDEATT Phone SN: R38G908HWCT Unique number: 06157DF6CCEC6F08 Reading IMEI... Ok IMEI: 354474070244008 (SIGN: OK) Checking hash file... Ok Reading data from phone... Ok Modem board: SHANNON333 HWID: 48 CE B7 8D 0E 04 00 00 00 00 00 00 00 00 00 00 Reading NV data... Ok Checking NV data... Ok Calculating... Ok Please wait, calculating codes... OK (time - 00:00:05) Freeze code: 36486831 NET lock: 81748646 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.28.1 |
The Following User Says Thank You to ghacks For This Useful Post: |
05-03-2017, 05:44 | #4 (permalink) |
No Life Poster Join Date: May 2009 Location: USA/NY
Member: 1025079 Status: Offline Thanks Meter: 311 | Hiding modem for people to pm, you? you are so funny man. Fake? are you sure about that? why don't you said, You dying to know what tool i am using lol. |
