02-09-2017, 16:14 | #1 (permalink) |
Freak Poster Join Date: Sep 2008 Location: Caracas, Venezuela. Age: 40
Member: 870866 Status: Offline Thanks Meter: 51 | SM-G928G IMEI Repair Fail with Z3X Box Code: REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair Selected model: SM-G928G Software version: 27.7 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Ok Reading phone info... Model: SM-G928G Android version: 6.0.1 Product code: Phone version: PDA version: G928GUBU3BQA3 CSC version: G928GUUB3BPL5 CSC country code: PANAMA CSC sales code: TPA HW version: Phone SN: R58H222CSXY Chip name: EXYNOS7420 Modem board: RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Can not detected modem type Done with Samsung Tool PRO v.27.7 |
02-10-2017, 14:39 | #2 (permalink) |
Member: 870866 Status: Offline Thanks Meter: 51 | Why Z3X supporters never answer my questions? That make me think that Z3X support is kind of bad You guys suppose to help us your customers. |
