02-10-2019, 21:26 | #1 (permalink) |
No Life Poster Join Date: Jun 2016 Location: UK
Member: 2581848 Status: Offline Thanks Meter: 249 | [WRONG TITLE] Refund credits please. [Answered] To unlock: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) To reset Pattern lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset Pattern Lock' button. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' to deactivate Google account activation lock. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) UNLOCK INSTRUCTIONS: To unlock: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) To reset Pattern lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset Pattern Lock' button. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' to deactivate Google account activation lock. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-G930T Software version: 34.8 Checking Login and Password... OK Ballance: 40 crd. You have 40 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G930T Android version: 6.0.1 PDA version: G930TUVS3APD8 CSC version: G930TTMB3APD8 Phone version: G930TUVS3APD8 Product code: SM-G930TZKATMB CSC country code: USA CSC sales code: TMB Phone SN: R58H23A3RPH IMEI: 357752070987370 HW version: REV0.6 RF cal date: 2016.02.29 Chip name: MSM8996 Modem board: MSM8996 Security patch: 2016-05-01 Boot Warranty bit: 0 SIM State: ABSENT Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM7 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Waiting ADB device... timeout Phone not found Done with Samsung Tool PRO v.34.8 hi the phone not unlocked and i dont see any adb -Waiting ADB device- refund please |
02-10-2019, 22:04 | #2 (permalink) |
Member: 2581848 Status: Offline Thanks Meter: 249 | charge me twice Operation: Unlock Selected model: SM-G930T Software version: 34.8 Checking Login and Password... OK Ballance: 40 crd. You have 40 credit(s) left. This operation takes 10 credits.Continue? No Operation: Unlock Selected model: SM-G930T Software version: 34.8 Checking Login and Password... OK Ballance: 40 crd. You have 40 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G930T Android version: 6.0.1 PDA version: G930TUVS3APD8 CSC version: G930TTMB3APD8 Phone version: G930TUVS3APD8 Product code: SM-G930TZKATMB CSC country code: USA CSC sales code: TMB Phone SN: R58H23A3RPH IMEI: 357752070987370 HW version: REV0.6 RF cal date: 2016.02.29 Chip name: MSM8996 Modem board: MSM8996 Security patch: 2016-05-01 Boot Warranty bit: 0 SIM State: ABSENT Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM7 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Waiting ADB device... timeout Phone not found Operation: Unlock Selected model: SM-G930T Software version: 34.8 Checking Login and Password... OK Ballance: 30 crd. You have 30 credit(s) left. This operation takes 10 credits.Continue? No Operation: Unlock Selected model: SM-G930T Software version: 34.8 Checking Login and Password... OK Ballance: 30 crd. You have 30 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G930T Android version: 6.0.1 PDA version: G930TUVS3APD8 CSC version: G930TTMB3APD8 Phone version: G930TUVS3APD8 Product code: SM-G930TZKATMB CSC country code: USA CSC sales code: TMB Phone SN: R58H23A3RPH IMEI: 357752070987370 HW version: REV0.6 RF cal date: 2016.02.29 Chip name: MSM8996 Modem board: MSM8996 Security patch: 2016-05-01 Boot Warranty bit: 0 SIM State: ABSENT Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM7 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Rebooting phone... OK Unlock done |
02-11-2019, 01:53 | #3 (permalink) |
Freak Poster Join Date: Jun 2016 Location: jordan
Member: 2588864 Status: Offline Thanks Meter: 62 | make your case to this mail they will solve your credit problem and attach your box no. and user name credit. with log of the operation [email protected] |
The Following User Says Thank You to pastday For This Useful Post: |
