01-30-2017, 12:16 | #1 (permalink) |
Freak Poster Join Date: Apr 2016 Location: Republic Of South Africa Age: 27
Member: 2562560 Status: Offline Thanks Meter: 56 | SM-G930F IMEI Repair Problem Code: Waiting ADB device... Ok Reading phone info... Model: SM-G930F Android version: 6.0.1 Product code: Phone version: G930FXXU1APBB PDA version: G930FXXU1APB9 CSC version: G930FDAX1APB2 CSC country code: AUSTRIA CSC sales code: TTR HW version: Phone SN: Chip name: EXYNOS8890 Modem board: SHANNON335 RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... error Security damaged (1) Done with Samsung Tool PRO v.27.6 |
01-30-2017, 14:53 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
01-30-2017, 16:03 | #3 (permalink) |
Member: 2562560 Status: Offline Thanks Meter: 56 | same result Code: REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair Selected model: SM-G930F Software version: 27.7 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Ok Reading phone info... Model: SM-G930F Android version: 6.0.1 Product code: Phone version: G930FXXU1APBB PDA version: G930FXXU1APB9 CSC version: G930FDAX1APB2 CSC country code: AUSTRIA CSC sales code: TTR HW version: Phone SN: Chip name: EXYNOS8890 Modem board: SHANNON335 RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... error Security damaged (1) Done with Samsung Tool PRO v.27.7 |
