01-13-2018, 05:13 | #1 (permalink) |
Junior Member Join Date: Nov 2017
Member: 2776971 Status: Offline Thanks Meter: 0 | SM-G930f patch cert imei repair need |
01-13-2018, 14:41 | #4 (permalink) |
No Life Poster Join Date: Sep 2015 Location: Everywhere Age: 29
Member: 2454192 Status: Offline Sonork: 100.1674433 Thanks Meter: 693 | you need reset efs first then write original nv data then repair imei unknown baseband after reboot cause of none original nv data if you dnt have original nv data of your phone contact me on skype i will try my best |
The Following 3 Users Say Thank You to Asad ali khan For This Useful Post: |
01-13-2018, 21:52 | #5 (permalink) |
Member: 2776971 Status: Offline Thanks Meter: 0 | Ok thank u for helping me i might have origanal nv data i have zex box wen i click on write nv data loads of files pop up like sm-g930f sm g935f etc .should I write the nv data ?? Thanks again |
01-13-2018, 22:15 | #6 (permalink) |
Member: 2776971 Status: Offline Thanks Meter: 0 | [QUOTE=Muckerz;12902537]Ok thank u for helping me i might have origanal nv data i have zex box wen i click on write nv data loads of files pop up like sm-g930f sm g935f etc .should I write the nv data ?? And how i reset efs |
01-13-2018, 22:47 | #7 (permalink) |
No Life Poster Join Date: May 2013 Location: Far From Home..:(
Member: 1948608 Status: Offline Thanks Meter: 1,744 | No need to flash EFS , just write MODEM from stock firmware and patch cert again,to avoid every time Unknown baseband issue,use old z3x ver.,coz new ver. Might have some bugs.... |
The Following User Says Thank You to -Mosin- For This Useful Post: |
01-17-2018, 16:27 | #12 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Ново&#
Member: 599694 Status: Offline Thanks Meter: 76 | I got same issue with g935fd. Afret reset EFS i get zero imei, but i dont have original nvdata Can it be fixed somehow? P.S. downgrading to 6.0.1 dosent change anything. |
01-17-2018, 18:06 | #13 (permalink) | |
Junior Member Join Date: Aug 2008 Location: Faisalabad, Pakistan Age: 39
Member: 834892 Status: Offline Sonork: softlabfsd Thanks Meter: 9 | Quote:
Download Factory Binary File for your model and 5 files firmware from z3x or from other sites. Start phone in Download mode and install Factory Binary with help of Odin. once it flash complete. the phone will boot into factory binary mode. and will try to restore factory functions. if it still show message "CP: uknown CP" then flash back to original firmware. 1. Root your Phone 2. Install Root Explorer and grant Super User Access 3. Open EFS folder and delete every thing Except "Factory App and prov_data" 4. Reboot your Phone, if it gives you some error, ignore its normal. 5. Flash Factory Binary firmware again, now it will restore everything to default regarding Modem. if you can see your IMEI after this, flash your phone with original firmware and enjoy. hit thanks if it works or for more help PM me. | |
