12-02-2017, 19:13 | #1 (permalink) |
Junior Member Join Date: Nov 2017
Member: 2779746 Status: Offline Thanks Meter: 0 | SM-G930F: Reading data from phone... error Operation: Repair DRK Selected model: SM-G930F Software version: 29.2 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash interface... COM4 detected Setup connection... OK Reading data from phone... error Done with Samsung Tool PRO v.29.2 |
12-02-2017, 19:42 | #2 (permalink) |
Member: 2779746 Status: Offline Thanks Meter: 0 | And I get this in download mode: Operation: Repair DRK Selected model: SM-G930F Software version: 29.2 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash interface... COM4 detected Setup connection... OK Reading data from phone... error Done with Samsung Tool PRO v.29.2 |
12-02-2017, 20:09 | #3 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Space Age: 49
Member: 861795 Status: Offline Thanks Meter: 1,275 | You are not using latest version of Z3X, latest version is 30.1 Also try rooting your phone it will fix DRK |
The Following User Says Thank You to voltran2008 For This Useful Post: |
12-02-2017, 20:18 | #4 (permalink) | |
Member: 2779746 Status: Offline Thanks Meter: 0 | Quote:
It's rooted and I get this now: Operation: Repair DRK Selected model: SM-G930F Software version: 30.1 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash interface... not found Done with Samsung Tool PRO v.30.1 | |
12-02-2017, 20:23 | #5 (permalink) | |
Member: 861795 Status: Offline Thanks Meter: 1,275 | Quote:
12-02-2017, 20:32 | #7 (permalink) |
Member: 861795 Status: Offline Thanks Meter: 1,275 | Well I recommend you to reflash your phone and use CF-Auto Root (6.0.1)... If you flash your phone with 7.0, I recommend you to use TWRP, but the process is a little bit complicated... |
12-02-2017, 20:45 | #8 (permalink) |
Member: 861795 Status: Offline Thanks Meter: 1,275 | Root for G930F on 7.0 with TWRP: (FRP: OFF) WARNING: This will wipe your device, backup your data Put your phone into download mode and run Odin Untick auto-reboot... Flash TWRP Recovery: twrp-3.2.0-0-herolte.img.tar After flashing TWRP, boot into recovery.. From wipe select Format Data... type yes and after wipe go back (keep hitting back icon) to Main Menu and select reboot, reboot to recovery.. After reboot browse to install and flash Supersu 2.82 (you can use SD-Card or OTG cable or ADB Push Command): SuperSU-v2.82-201705271822.zip Reboot your device... this will take up to 5 minutes PS: Wipe data is a MUST because when you swipe TWRP it will trigger dm-verity, and if you don't wipe you will be unable to boot |
12-02-2017, 22:27 | #9 (permalink) |
Member: 2779746 Status: Offline Thanks Meter: 0 | Will I be able to make OTA Updates? For example I want to give my phone to someone who doesn't know anything about flashing and rooting... Will he be able to do updates by him self? |
12-03-2017, 00:08 | #10 (permalink) | |
Same applies DRK repair... it also disables OTA updates... Last edited by voltran2008; 12-03-2017 at 00:14. Reason: typing... | |
