sm-g930fd imei repair done BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Write CERT' to restore certificates. 7. Press 'Write NV DATA' if you need to restore NV backup. Read certificate operation: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read CERT' button to read certificates. (Note, that the cert file for this model is unique. You can write cert, wich is readed from this device exactly.) Operation: Patch Certificate Selected model: SM-G930FD Software version: 27.4 Waiting ADB device... Ok Reading phone info... Model: SM-G930F Android version: 6.0.1 Product code: SM-G930FZSUTHR Phone version: G930FXXU1BPH1 PDA version: G930FXXU1BPH6 CSC version: G930FOJV1BPH3 CSC country code: IRAN CSC sales code: THR HW version: MP 0.700 Phone SN: R58H41QV6FW Chip name: EXYNOS8890 Modem board: SHANNON335 RF cal date: 20160412 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Detecting MODEM... Ok Reading MODEM... Ok Calculating... Ok Writing zTool... Ok Initialization zTool... Ok Rebooting phone... Ok Patching CERT check... done Done with Samsung Tool PRO v.27.4 THANKS TO Z3X TEAM :):):):):):):):):) |
