Old 12-06-2016, 17:25   #1 (permalink)
Member: 1391134
Thanks Meter: 47
sm-g930fd imei repair done
BACKUP INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Read EFS' button to read backup or 'Write EFS' to restore.
6. Press 'Write CERT' to restore certificates.
7. Press 'Write NV DATA' if you need to restore NV backup.
Read certificate operation:
2. Connect the phone to PC with USB cable.
3. Check Samsung modem in device manager, install drivers if needed.
4. Press 'Read CERT' button to read certificates.
(Note, that the cert file for this model is unique. You can write cert, wich is readed from this device exactly.)
Operation: Patch Certificate
Selected model: SM-G930FD
Software version: 27.4
Waiting ADB device... Ok
Reading phone info...
Model: SM-G930F
Android version: 6.0.1
Product code: SM-G930FZSUTHR
Phone version: G930FXXU1BPH1
PDA version: G930FXXU1BPH6
CSC version: G930FOJV1BPH3
CSC country code: IRAN
CSC sales code: THR
HW version: MP 0.700
Phone SN: R58H41QV6FW
Chip name: EXYNOS8890
Modem board: SHANNON335
RF cal date: 20160412
IMEI:
Checking Super user right... true
Reading NV data... Ok
Checking NV data... Ok
Detecting MODEM... Ok
Reading MODEM... Ok
Calculating... Ok
Writing zTool... Ok
Initialization zTool... Ok
Rebooting phone... Ok
Patching CERT check... done
Done with Samsung Tool PRO v.27.4
THANKS TO Z3X TEAM
Old 09-13-2017, 04:08   #2 (permalink)
Member: 2565567
Model: SM-G930F
CSC sales code: THR
IMEI:
Reading MODEM... Ok
Calculating... Ok
Writing zTool... Ok
THANKS TO Z3X TEAM
Can you share the cert please?
Old 09-13-2017, 20:58   #3 (permalink)
Member: 2683817
Thanks Meter: 29
Are you seriously he used Repair function and to Repair network made patch certificate. Check software log.
Page generated in 0.14230 seconds with 8 queries
