01-31-2018, 09:44 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | Sm-g930p the build qj3 unlock via combo after flash stock rom [ 1/31/2018 3:12:00 AM ] Selected model: SM-G930P [ 1/31/2018 3:12:00 AM ] Software version: 30.5 [ 1/31/2018 3:12:00 AM ] [ 1/31/2018 3:12:00 AM ] Searching phone and switching to flash mode... OK [ 1/31/2018 3:12:00 AM ] [ 1/31/2018 3:27:00 AM ] Operation: Unlock [ 1/31/2018 3:27:00 AM ] Selected model: SM-G930P [ 1/31/2018 3:27:00 AM ] Software version: 30.5 [ 1/31/2018 3:27:00 AM ] [ 1/31/2018 3:27:00 AM ] Waiting ADB device... OK [ 1/31/2018 3:27:00 AM ] Reading phone info... [ 1/31/2018 3:27:00 AM ] Model: SM-G930V [ 1/31/2018 3:27:00 AM ] Android version: 6.0.1 [ 1/31/2018 3:27:00 AM ] Product code: Not Active [ 1/31/2018 3:27:00 AM ] Phone version: G930PVPU4AQI1 [ 1/31/2018 3:27:00 AM ] PDA version: FA60_G930PVPU5AQI1 [ 1/31/2018 3:27:00 AM ] CSC version: [ 1/31/2018 3:27:00 AM ] CSC country code: [ 1/31/2018 3:27:00 AM ] CSC sales code: [ 1/31/2018 3:27:00 AM ] HW version: REV0.6 [ 1/31/2018 3:27:00 AM ] Phone SN: 00000000000 [ 1/31/2018 3:27:00 AM ] Modem board: MSM8996 [ 1/31/2018 3:27:00 AM ] Security patch: 2016-01-01 [ 1/31/2018 3:27:00 AM ] RF cal date: 2016.05.27 [ 1/31/2018 3:27:00 AM ] IMEI: 358991073528349 [ 1/31/2018 3:27:00 AM ] Writing AT RIL... OK [ 1/31/2018 3:27:00 AM ] Initialization AT RIL... OK [ 1/31/2018 3:27:00 AM ] Unlocking... OK [ 1/31/2018 3:27:00 AM ] Rebooting phone... OK [ 1/31/2018 3:27:00 AM ] Unlock done DON'T ASK ME COMBINATION GO TO WWW.ANDROIDFILEHOST.COM ITS ALREADY AVAILABLE OVER INTERNET THAT THE NAME COMBO COMBINATION_FA60_G930PVPU5AQI1 OR PM PRIVATE MSG. Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Enter Recovery and enable CP Logging, reboot phone. 3. Type ##3424# and select Enable DM Mode. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect the phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Flash Selected model: SM-G930P Software version: 30.5 File analysis... OK Total file size: 0x1335AB332 (4917 Mb) Searching USB Flash interface... COM3 detected Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending emmc_appsboot.mbn... OK Sending lksecapp.mbn... OK Sending xbl.elf... OK Sending tz.mbn... OK Sending hyp.mbn... OK Sending devcfg.mbn... OK Sending pmic.elf... OK Sending rpm.mbn... OK Sending cmnlib.mbn... OK Sending keymaster.mbn... OK Sending apdp.mbn... OK Sending msadp.mbn... OK Sending cmnlib64.mbn... OK Sending sec.dat... OK Sending NON-HLOS.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img.ext4... OK Sending persist.img.ext4... OK Sending modem.bin... OK Sending adspso.bin... OK Sending cache.img.ext4... OK Flashing done (time - 00:04:33) Done with Samsung Tool PRO v.30.5 |
