06-27-2019, 12:37 | #1 (permalink) |
Freak Poster Join Date: Jul 2013 Location: In your heart.
Member: 1973579 Status: Offline Thanks Meter: 30 | SM-G930W8/G930F repair failed [Answered] REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on the phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair Selected model: SM-G930W8 Software version: 35.3 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: SM-G930FD Android version: 7.0 PDA version: G930FDXXU1DQG1 CSC version: G935FOXE1DQG1 Phone version: G930W8VLU5ARI1 Product code: CSC country code: UAE CSC sales code: XSG Phone SN: R4587300SP IMEI: XXXXXXXXXXXXX HW version: RF cal date: Chip name: EXYNOS8890 Modem board: SHANNON335 Security patch: 2017-07-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Incorrect model selected. This may damage your phone. Continue? Yes Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... OK Reading data... error (1) Initialization zTool... error (0 1) Try downgrade modem if possible Done with Samsung Tool PRO v.35.3 |
06-27-2019, 17:03 | #2 (permalink) | |
Product Supporter Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Quote:
Sent from my SM-N950F using Tapatalk | |
06-27-2019, 17:42 | #3 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Quote:
I checked the Canadian warranty based on the serial R4587300SP, but it doesn't come up, which means it's the international model SM-G930FD. You have probably flashed the modem part only with the Canadian G930W8, so you should reflash it with the correct model firmware for SM-G930FD | |
06-28-2019, 06:29 | #4 (permalink) | |
Member: 1973579 Status: Offline Thanks Meter: 30 | Quote:
Hello. Its G930W8 sn is changed. I had checked in download mode!! | |
