SM-G935f 8.0 frp How to [Solved] UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Reset FRP/React/EE Selected model: SM-G935F Software version: 26.1 Checking local file... not found Searching server... OK Downloading file... OK Checking local file... OK Searching USB Flash Interface... detected COM42 Setup connection... OK Reading data from phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: SM-G935FZDAMTZ Phone version: G935FXXU1APEQ PDA version: G935FXXU1APF2 CSC version: G935FOJV1APF1 CSC country code: Zambia CSC sales code: MTZ HW version: MP 0.801 Phone S/N: RF8H22GQ49R Modem board: SHANNON335 RF cal date: 20160228 IMEI: Checking Super user right... true Erasing FRP... OK Restore original kernel? Yes Checking local file... not found Searching server... OK Downloading file... OK Checking local file... OK Restoring kernel... OK Rebooting phone... OK Reset FRP done Done with Samsung Tool PRO v.26.1 |
n935f Checking hash file... OK Searching Samsung modem... detected COM27 Reading phone info... OK Model: SM-N935F AP version: N935FXXU1AQI5 CSC version: N935FOJV1AQI5 CP version: N935FXXU1AQI5 Product code: KSA Phone SN: RF8JB0H804Z Unique number: CE10171A7B0DE11B01 Searching Samsung diag port... detected COM28 Reading phone info... OK CP version: N935FXXU1AQI5 CP build: Sep 19 2017 17:20:32 Reading data from phone... OK Reading NV data... OK Modem board: SHANNON335 Checking NV data... OK Calculating... OK Please wait, calculating codes... OK (time - 00:00:02) Freeze code: 93084938 NET lock: 19485269 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.30.4 |
where download combination file? |
Need combination file n935f please. |
G935f binnery 2 frp done one click viya frp ufs MANY BOXES FAILE NO COMBINATION NO ANOTHER FILE NO ADB JUST ONE CLICK LATEST SECURTY FRP REMOVE UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To read security codes via diagnostic port: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't use this function. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes DIAG' button to read security codes. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' to deactivate Google account activation lock. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) To reset Google account activation lock with UART cable: 1. Phone must be powered off 2. Connect the phone to UART cable. 3. Select correct COM port in port settings. 4. Press 'Reset FRP UFS' and follow the instructions in program. Operation: Reset FRP UFS Selected model: SM-G935F Selected port: COM1 USB Serial Port Software version: 31.5.1 Hold 'Vol down' and press 'POWER ON' for 2-3 seconds Checking phone at COM1 OK Phone detected, do not release 'Vol down' Reading data from phone... OK Release 'Vol down' now Comparing selected model... match (G935F) Setup connection... OK Reseting FRP... OK Rebooting phone... OK Reset FRP done Done with Samsung Tool PRO v.31.5.1 |
G935F 8.0 reset frp not done ? [Answered] salem Operation: Reset FRP UFS Selected model: SM-G935F Selected port: COM5 USB Serial Port Software version: 33.2 Hold 'Vol down' and press 'POWER ON' for 2-3 seconds Checking phone at COM5 OK Phone detected, do not release 'Vol down' Reading data from phone... OK Release 'Vol down' now Comparing selected model... match (G935F) Setup connection... OK Reseting FRP... error (1) Done with Samsung Tool PRO v.33.2 |
Try to downgrade 8 not supported yet Sent from my iPhone using Tapatalk |
Or flash it with sboot version 7 Best regards Sent from my iPhone using Tapatalk |
Open ADB to remove FRP |
1. Downgrade to (Binary 2) 7.0 firmware and use Refet FRP UFS 2. Combination method and enable ADB and Reset FRP |
https://drive.google.com/uc?id=1F6oI...xport=download |
i do this same logs Reseting FRP... OK Rebooting phone... OK Reset FRP done but phone is still FRP lock same binary2 (U2) |
full flash and again reset frp viya frp ufs |
i already flashed because before its hang on logo |
