Old 07-27-2016, 13:35   #1 (permalink)
Member: 361348
Thanks Meter: 627
SM-G935f 8.0 frp How to [Solved]
UNLOCK INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes.
Operation: Reset FRP/React/EE
Selected model: SM-G935F
Software version: 26.1
Checking local file... not found
Searching server... OK
Downloading file... OK
Checking local file... OK
Searching USB Flash Interface... detected COM42
Setup connection... OK
Reading data from phone... OK
Sending data to phone... OK
Waiting ADB device... OK
Reading phone info...
Model: SM-G935F
Android version: 6.0.1
Product code: SM-G935FZDAMTZ
Phone version: G935FXXU1APEQ
PDA version: G935FXXU1APF2
CSC version: G935FOJV1APF1
CSC country code: Zambia
CSC sales code: MTZ
HW version: MP 0.801
Phone S/N: RF8H22GQ49R
Modem board: SHANNON335
RF cal date: 20160228
IMEI:
Checking Super user right... true
Erasing FRP... OK
Restore original kernel? Yes
Restoring kernel... OK
Rebooting phone... OK
Reset FRP done
Done with Samsung Tool PRO v.26.1
Old 01-12-2018, 12:14   #2 (permalink)
Member: 2380725
Thanks Meter: 12
Arrow n935f
Checking hash file... OK
Searching Samsung modem... detected COM27
Reading phone info... OK
Model: SM-N935F
AP version: N935FXXU1AQI5
CSC version: N935FOJV1AQI5
CP version: N935FXXU1AQI5
Product code: KSA
Phone SN: RF8JB0H804Z
Unique number: CE10171A7B0DE11B01
Searching Samsung diag port... detected COM28
CP build: Sep 19 2017 17:20:32
Reading NV data... OK
Checking NV data... OK
Calculating... OK
Please wait, calculating codes... OK (time - 00:00:02)
Freeze code: 93084938
NET lock: 19485269
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
For check lock status: *#7465625#
Done with Samsung Tool PRO v.30.4
Old 03-20-2018, 12:44   #3 (permalink)
Member: 1596237
Sonork: DijeMuyie
Thanks Meter: 30
where download combination file?
Old 04-11-2018, 17:07   #4 (permalink)
Member: 2711124
Thanks Meter: 37
the combination Toll
Old 04-12-2018, 15:03   #5 (permalink)
Member: 2029667
Thanks Meter: 4
Need combination file n935f please.
Old 05-22-2018, 18:11   #6 (permalink)
faisal jee's Avatar
Member: 882981
Sonork: 161363
Thanks Meter: 244
G935f binnery 2 frp done one click viya frp ufs
MANY BOXES FAILE
NO COMBINATION NO ANOTHER FILE NO ADB
JUST ONE CLICK LATEST SECURTY FRP REMOVE
To unlock NEW security type:
5. Press 'Unlock' button and select 'New Unlock' for direct unlock.
To unlock OLD security type:
2. Connect the phone to PC with USB cable.
3. Check Samsung modem in device manager, install drivers if needed.
4. Press 'Unlock' button and select 'Unlock' for direct unlock.
To read security codes (all security types):
4. Press 'Read codes' button to read security codes.
To read security codes via diagnostic port:
Warning! Knox warranty must be active (0x00)!
If you have it voided (0x01(void)), then you can't use this function.
2. Type *#0808# and select 'DM+MODEM+ADB'.
4. Press 'Read Codes DIAG' button to read security codes.
To reset Google account activation lock:
1. ADB must be activated in any way (you can flash sBoot from combination firmware,
make sure, that you are not upgrade sBoot).
2. Connect the phone to PC with USB cable, install drivers if needed.
3. Select device in ADB settings.
4. Press 'Reset FRP' to deactivate Google account activation lock.
To reset Google account activation or Samsung reactivation lock:
1. Power on the phone in download mode (turn off phone, press vol.down + home + power).
3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
(Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.)
To reset Google account activation lock with UART cable:
1. Phone must be powered off
2. Connect the phone to UART cable.
3. Select correct COM port in port settings.
4. Press 'Reset FRP UFS' and follow the instructions in program.
Operation: Reset FRP UFS
Selected port: COM1 USB Serial Port
Software version: 31.5.1
Hold 'Vol down' and press 'POWER ON' for 2-3 seconds
Checking phone at COM1 OK
Phone detected, do not release 'Vol down'
Release 'Vol down' now
Comparing selected model... match (G935F)
Reseting FRP... OK
Reset FRP done
Done with Samsung Tool PRO v.31.5.1
The Following User Says Thank You to faisal jee For This Useful Post:
Old 07-12-2018, 23:20   #7 (permalink)
Member: 1690056
Thanks Meter: 60
G935F 8.0 reset frp not done ? [Answered]
salem
Selected port: COM5 USB Serial Port
Software version: 33.2
Checking phone at COM5 OK
Reseting FRP... error (1)
Done with Samsung Tool PRO v.33.2
Old 07-13-2018, 02:11   #8 (permalink)
princemeedo's Avatar
Member: 2737570
Thanks Meter: 53
Originally Posted by soltacom View Post
salem
Try to downgrade 8 not supported yet
Sent from my iPhone using Tapatalk
Old 07-13-2018, 06:39   #9 (permalink)
Member: 2737570
Thanks Meter: 53
salem
Or flash it with sboot version 7
Best regards
Old 07-13-2018, 07:16   #10 (permalink)
Member: 2758069
Thanks Meter: 10
Open ADB to remove FRP
Old 07-13-2018, 08:50   #11 (permalink)
voltran2008's Avatar
Member: 861795
Thanks Meter: 946
salem
You can try these 2 solutions:
1. Downgrade to (Binary 2) 7.0 firmware and use Refet FRP UFS
2. Combination method and enable ADB and Reset FRP
Old 07-22-2018, 18:15   #12 (permalink)
Member: 2219780
Sonork: 100.1662738
Thanks Meter: 45
https://drive.google.com/uc?id=1F6oI...xport=download
The Following User Says Thank You to Amr.OKa For This Useful Post:
Old 08-09-2018, 10:33   #13 (permalink)
Member: 2090936
Thanks Meter: 25
i do this same logs
Reseting FRP... OK
Reset FRP done
but phone is still FRP lock
same binary2 (U2)
Old 08-09-2018, 10:53   #14 (permalink)
Member: 921938
full flash and again reset frp viya frp ufs
Old 08-09-2018, 12:20   #15 (permalink)
Member: 2090936
Thanks Meter: 25
i already flashed because before its hang on logo
Page generated in 0.46860 seconds with 7 queries
