Old 08-15-2018, 15:33   #31 (permalink)
Member: 2263412
Thanks Meter: 86
Originally Posted by Stevefilby View Post
Hi
Tried to remove FRP via UART, software claimed success but FRP still on
Tried to flash combination from support
combination FA60 G935FXXU2ARA but phone enters bootloader exception
(black screen with red and green writing).
I have now flashed back to stock rom.
Is there a solution?
or a combinatiom file?
Thank you
Steve
Samsung SM-G935F Galaxy S7 Frp Lock Remove Final Solution
First download and Flash With Sm-G935F Firmware:
G935FXXS2DRAA android 7.0 on z3x support
Next download this G935F_ENG_ROOT and flash:
https://drive.google.com/file/d/1W4T...ew?ts=5b727e87
Now reset factory, after reset restart and your adb is on
Press thanks Button
The Following User Says Thank You to pink009 For This Useful Post:
Old 08-15-2018, 15:39   #32 (permalink)
DomnulV's Avatar
Member: 1447
Thanks Meter: 97
TNX, but not ***, write system.img part is not done.
Old 08-28-2018, 19:05   #33 (permalink)
Member: 85718
Thanks Meter: 448
G935F FRP error
Hi, trying to remove FRP using UART cable with Z3X but fail to read phone . Tryed many times but all the time same error.
Any ideia ?
Tryed two diferent UART cables in Z3X , tryed prolific cable (usb/serial) and the same error.
Operation: Reset FRP UFS
Selected model: SM-G935F
Selected port: COM5 Z3X BOX Serial Port
Software version: 33.5
Hold 'Vol down' and press 'POWER ON' for 2-3 seconds
Checking phone at COM5 OK
Phone detected, do not release 'Vol down'
Reading data from phone... error (2)
Done with Samsung Tool PRO v.33.5
Old 08-29-2018, 03:52   #34 (permalink)
reyxito's Avatar
Member: 2549748
Thanks Meter: 212
try with combinat or eng root
Old 09-03-2018, 15:50   #35 (permalink)
Member: 85718
Thanks Meter: 448
Could you please provide a working link? Thank you .
Press thanks Button
Old 09-03-2018, 16:01   #36 (permalink)
Member: 85718
Thanks Meter: 448
Hi
NOW SOLVED
I reflashed with stock software, Android 7.0, then I removed FRP via UART.
All Done.
Thank you!
Steve
Please confirm the version you have flashed.
Thank you.
Old 09-06-2018, 17:30   #37 (permalink)
Member: 85718
Thanks Meter: 448
Thank you.
Now have solved the FRP using Z3X interface and other tool. Probably version 33.7 I am using have bugs.
Old 09-19-2018, 22:49   #38 (permalink)
unlockgod's Avatar
Member: 5285
Thanks Meter: 82
I Managed to complete the FRP removal by using combination firmware
Flash combination file
go to settings on the phone and enable adb by going to developer mode (usual way)
then connect to z3x in flash mode
and select UFS FRP removal
Reflash full firmware 8.0
NO NEED TO DOWNGRADE and no loss of Knox
Old 09-24-2018, 14:14   #39 (permalink)
Member: 2495115
Thanks Meter: 34
SM-G935f frp
g935f FRP
rec'd g935 for FRP reset
tried to flash combination files from support all files cause phone to enter screen with lots of red and green writing!
I tink this phone is binary 3
SWREV B:3 K:1 S:2
firmware G935 FXXS3
I have also found combination files from other posts (COMBINATION FA60 G935FXXU3), These give the same screen with red and green writing.
I have also tried z3x FRP by UART
Any ideas??
Thank yo
Steve
Old 09-24-2018, 20:27   #40 (permalink)
Member: 2085676
Thanks Meter: 299
try to 1st full flash with other binary 3 file
after use combination file
after post log data please ...
Old 09-25-2018, 07:38   #41 (permalink)
Member: 2603680
Thanks Meter: 25
Downgrade to 7
You can't remove frp using Combination file in this model because it always gives bootloader exception error. Downgrade your phone to android 7 with having same binary. Then flash eng boot and hard reset your phone after that your phone will have adb enabled and reset frp through any box. This is tested by me.
The Following User Says Thank You to bishesh10 For This Useful Post:
Old 09-25-2018, 15:00   #42 (permalink)
Member: 2495115
Thanks Meter: 34
This phone was manually updated by the owner to Oreo 8 Binary 3!
I cannot find a binary 3 For android 7,
For the G935?
any Ideas please?
Thank you
Steve
Old 09-25-2018, 15:15   #43 (permalink)
Member: 2620145
Thanks Meter: 319
use urat cabel within 2se remove frp
Old 09-30-2018, 12:36   #44 (permalink)
Member: 2495115
Thanks Meter: 34
URT method does not work for this model, with binary 3
Steve
Old 10-02-2018, 13:42   #45 (permalink)
iqballk's Avatar
Member: 13932
Sonork: 100.1609876
Thanks Meter: 410
Request: g935f u3 frp solution
phone has G935FXXS3ERHD firmware. U3 combination not work. coz the stock has newest boot. emmc or ufs method not work.
any fix appreciated..!
Page generated in 0.37590 seconds with 8 queries
