10-20-2018, 15:36 | #64 (permalink) |
No Life Poster Join Date: Aug 2012 Location: Bali-Indonesia
Member: 1800628 Status: Offline Thanks Meter: 937 | G935F U3 easy remove FRP by Z3X 1.flash with combination U3(download on support area 2.Flash combination with latest odin(dont use Z3X) 3.after finish write combination with odin do reset frp UFS method by Z3X. (enter download mode you will see FRP Lock Off) 4.flash stockrom U3. all done......... [ 20/10/2018 22:26:28 ] Operation: Reset FRP UFS [ 20/10/2018 22:26:28 ] Selected model: SM-G935F [ 20/10/2018 22:26:28 ] Selected port: COM37 Z3X BOX Serial Port [ 20/10/2018 22:26:28 ] Software version: 34.0 [ 20/10/2018 22:26:28 ] [ 20/10/2018 22:26:29 ] Hold 'Vol down' and press 'POWER ON' for 2-3 seconds [ 20/10/2018 22:26:29 ] Checking phone at COM37 OK [ 20/10/2018 22:26:54 ] Phone detected, do not release 'Vol down' [ 20/10/2018 22:26:54 ] Reading data from phone... OK [ 20/10/2018 22:26:56 ] Release 'Vol down' now [ 20/10/2018 22:26:58 ] Comparing selected model... match (G935F) [ 20/10/2018 22:26:58 ] Setup connection... OK [ 20/10/2018 22:26:59 ] Reseting FRP... OK [ 20/10/2018 22:26:59 ] Rebooting phone... OK [ 20/10/2018 22:27:01 ] Reset FRP done [ 20/10/2018 22:27:01 ] [ 20/10/2018 22:27:52 ] Operation: Flash [ 20/10/2018 22:27:53 ] Selected model: SM-G935F [ 20/10/2018 22:27:53 ] Software version: 34.0 [ 20/10/2018 22:27:53 ] [ 20/10/2018 22:27:53 ] File analysis... OK [ 20/10/2018 22:27:54 ] Total file size: 0x100FEF5E1 (4111 Mb) [ 20/10/2018 22:27:54 ] Searching USB Flash interface... COM33 detected [ 20/10/2018 22:27:55 ] Setup connection... OK [ 20/10/2018 22:27:55 ] Set PIT file... OK [ 20/10/2018 22:27:55 ] Reading PIT from phone... OK [ 20/10/2018 22:27:56 ] Sending sboot.bin.lz4... OK [ 20/10/2018 22:27:57 ] Sending param.bin.lz4... OK [ 20/10/2018 22:27:57 ] Sending cm.bin.lz4... OK [ 20/10/2018 22:27:58 ] Sending boot.img.lz4... OK [ 20/10/2018 22:28:01 ] Sending recovery.img.lz4... OK [ 20/10/2018 22:28:04 ] Sending system.img.lz4... OK [ 20/10/2018 22:31:43 ] Sending modem.bin... OK [ 20/10/2018 22:31:46 ] Sending modem_debug.bin... OK [ 20/10/2018 22:31:47 ] Sending cache.img.lz4... OK [ 20/10/2018 22:31:49 ] Sending hidden.img.lz4... OK [ 20/10/2018 22:31:51 ] Flashing done (time - 00:03:56) |
The Following 6 Users Say Thank You to Deni's For This Useful Post: |
10-24-2018, 13:08 | #68 (permalink) |
Insane Poster Join Date: Nov 2009
Member: 1168892 Status: Offline Thanks Meter: 14 | Samsung G935f 8.0 u3 FRP Hi to all, need some info about frp or downgrade on this model with this firmware - 8.0.0/R16NW/G935FXXS3ERHD Is it possible to remove frp or downgrade this version to android 7.0 u2 to be able to make frp reset with z3x and how to do it!? Thanks for any help in advance |
10-24-2018, 13:12 | #69 (permalink) | |
Product Supporter Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Quote:
The Following User Says Thank You to souma_k For This Useful Post: |
10-24-2018, 14:55 | #75 (permalink) |
Member: 1168892 Status: Offline Thanks Meter: 14 | tryed that trick whithout success,removed bat than enter download mode and flash with G935FXXS3ERHD_OXA3ERGE from suport and than same combination flash with odin,now Il try to make frp reset... |
The Following User Says Thank You to zeljko1896 For This Useful Post: |
