12-29-2016, 13:23 | #1 (permalink) |
Freak Poster Join Date: Mar 2009 Location: TÜRKİYE
Member: 1001450 Status: Offline Thanks Meter: 28 | sm-g935f after factory reset imei status:NG patc certificate z3x imei status ok after factory reset imei status NG help plase |
12-29-2016, 15:47 | #4 (permalink) |
Freak Poster Join Date: May 2005
Member: 149004 Status: Offline Thanks Meter: 14 | Hi, can i ask you a question ? I'm trying 2 days to repair and each certificate, i don't get errors during the procedure, but the status imli are always NG, no hard reset, no notting Tool Pro V27.6 says everything it's done, but that's no true, i tried with different fw versions, but the result are always the same. Any help ? I'm new Z3X user but i think to do the correct procedure. Regards. Ice. Now i'm using G935FXXU1APB4 fw |
12-29-2016, 21:28 | #5 (permalink) | |
Junior Member Join Date: Apr 2015
Member: 2372429 Status: Offline Thanks Meter: 0 | Quote:
01-02-2017, 01:26 | #9 (permalink) |
Product Supporter Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Hello This is patch temporarily not permanent if you make factory reset or unroot u lose all what you did soo leave the phone rooted and don't do factory reset if you need signal Sent from my SM-G935F using Tapatalk |
01-02-2017, 18:03 | #10 (permalink) |
Member: 149004 Status: Offline Thanks Meter: 14 | Just to make everything easy: 1- After pach certificate it's no possible to reset the phone, if you do you gona lose the pach. 2- After pach certificate it's no possible to flash phone with other fw, if you do you gona lose the pach. 3- I haven't find any problem unrooting the phone, so you can unroot it without losing the pach. That's all. Regards. Ice. |
The Following User Says Thank You to icecool67 For This Useful Post: |
02-20-2017, 12:08 | #11 (permalink) |
Junior Member Join Date: Sep 2011 Location: Russia, Moscow
Member: 1660369 Status: Offline Thanks Meter: 1 | SM-G935F After write Cert File Dial *#06# IMEI Cert O.K. , Dial *#0011# IMEI Status :NG !!! Not registered on network !!! Patch sert - All good! After hard reset IMEI Status :NG (((( How fix this? |
02-20-2017, 12:16 | #12 (permalink) | |
No Life Poster Join Date: May 2016
Member: 2577670 Status: Offline Thanks Meter: 883 | Quote:
CLICK ON THE THANKS BUTTON IF THIS POST WAS HELPFULL | |
02-21-2017, 09:22 | #13 (permalink) | |
Member: 1660369 Status: Offline Thanks Meter: 1 | Quote:
This not permanent pach (((( May be exist fix | |
