07-16-2016, 18:00 | #1 (permalink) |
Freak Poster Join Date: Aug 2012 Location: england
Member: 1798097 Status: Offline Thanks Meter: 86 | SM-G935F DMVT repair error Log: REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair DRK Selected model: SM-G935F Software version: 26.0 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash Interface... detected COM6 Setup connection... OK Reading data from phone... OK Sending data to phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Android version: 6.0.1 Boot version: G935FXXS1APG5 Platform: exynos7420 Boot serial: ce051605b2a0a80805 Product board: herolte Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Checking DRK status... OK Repairing DMVT key... error Rebooting phone... OK Repair DRK done Done with Samsung Tool PRO v.26.0 After this error the phone restarts and keeps restarting all the time. i flashed with BTU firmware, with all different firmwares but still not able to repair the DMVT KEY. Anyone with help would be really appreciated. Blang? have you got any opinion about this? Thank you |
07-17-2016, 12:58 | #5 (permalink) | |
Member: 1798097 Status: Offline Thanks Meter: 86 | Quote:
Thanks guys fixed. i just had to root and flash it again with stock like expenaticx and ajmalkhan713 said. | |
10-17-2016, 23:44 | #6 (permalink) |
Junior Member Join Date: Feb 2015
Member: 2349027 Status: Offline Thanks Meter: 0 | Operation: Repair DRK Selected model: SM-G930F Software version: 26.9 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash interface... COM11 detected Setup connection... OK Reading data from phone... OK Sending data to phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Recovery build version: 6.0.1 Boot version: G930FXXU1BPH6 Platform: exynos5 Boot serial: 9886274a414e594c4b Product board: universal8890 Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Checking DRK status... OK Repairing DMVT key... error Rebooting phone... OK Repair DRK done Done with Samsung Tool PRO v.26.9 cf auto root not working for me... |
