08-26-2018, 08:57 | #1 (permalink) |
Freak Poster Join Date: Jul 2006 Location: Dubai
Member: 319509 Status: Offline Thanks Meter: 17 | SM-G935f flashing "csc" error??? [Answered] 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G935F Software version: 33.5 File analysis... OK Total file size: 0x0EE6533C (238 Mb) Searching USB Flash interface... COM36 detected Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending cache.img... OK Sending hidden.img... OK Flashing done (time - 00:00:21) Done with Samsung Tool PRO v.33.5 problem on handset is frp only... 1:i am flashed lates version =only csc and modem failed 2:downgraded same binary =same error "custom ninary blocked by frp" what is the problem i am not downgrading the handset latest 8.0.0 also itried set showing "custom binary blocked by frp" bl and ap flashing good but csc and modem failed |
08-26-2018, 09:09 | #2 (permalink) | |
No Life Poster Join Date: Oct 2015 Location: Pakistan
Member: 2478233 Status: Offline Thanks Meter: 596 | Quote:
08-26-2018, 10:13 | #3 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Space Age: 49
Member: 861795 Status: Offline Thanks Meter: 1,275 | Open CSC (not HOME_CSC) file with WinRAR you will find PIT file in it and extract PIT file... Afterwards flash with PIT file.... |
The Following 2 Users Say Thank You to voltran2008 For This Useful Post: |
