10-17-2016, 15:04 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: FOCSANI Age: 39
Member: 718470 Status: Offline Thanks Meter: 79 | sm-g935f reset frp done but frp on????? Selected model: SM-G935F Software version: 26.9 Waiting ADB device... OK Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: SM-G935FEDAPHE Phone version: G935FXXU1APG1 PDA version: FA60_G935FXXU1APG1 CSC version: CSC country code: CSC sales code: HW version: MP 0.801 Phone SN: R58H73K7HEK Modem board: SHANNON335 RF cal date: 20160722 IMEI: Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.26.9 after factory data reset frp on pls help |
10-18-2016, 09:44 | #5 (permalink) |
Member: 718470 Status: Offline Thanks Meter: 79 | i write all combination files on suport in adb mode reset frp done factory reset on meniu after restart frp on reset frp z3x, octoplus nck frp on after reset frp ok and factory reset |
10-18-2016, 10:05 | #6 (permalink) | |
Product Supporter Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Hello bro Flash combination sboot from shell and try to reset frp it should work . Quote:
Sent from my SM-G935F using Tapatalk | |
10-18-2016, 14:03 | #9 (permalink) | |
No Life Poster Join Date: Sep 2015 Location: Everywhere Age: 29
Member: 2454192 Status: Offline Sonork: 100.1674433 Thanks Meter: 693 | Quote:
10-19-2016, 04:44 | #11 (permalink) |
No Life Poster Join Date: Apr 2005 Location: brunei
Member: 141262 Status: Offline Thanks Meter: 348 | Asad ali khan is correct if you are having a hard time try manually removing S7 frp via realterm 1. Download and install RealTerm program 2. Download and copy com.rootjunky.frpbypass-1.0.apk to the device micro sdcard or download once into the device 3. start phone and connect to WIFI also plug into the computer with your usb cable 4. start RealTerm on your pc and under pisplay check the box HALF DUPLEX 5. right click on my computer and select manage once it opens click device manager then modems 6. under modems you should see a Samsung device. right click it then select properties 7. once the properties window opens select modem tab and see what port it is on like com5 for an example 8. now that you know the com port number close all device manager windows and open RealTerm again 9. under the ports tab in RealTerm enter your port number then click change. 10. next click the send tab. you will need to send these two commands with the Send ASCII button first at+creg?\r\n then atd1234;\r\n look at your phone and the dailer will pop up. 11. then remove from usb; scroll down then click scan business card and then click download so you go to samsung apps to download es file explorer and enter your samsung account to download. 12. afterward install rootjunky.frpbypass-1.0.apk open it and click the menu on the right upper part of the apps and enter your google account wait for it then restart your phone... 13. your google account and samsung account be in the phone so what i do is remove those accounts and then factory reset your phone.. a. if your version is marsmallow you should download also this Android_6_Google_Account_Manager.apk.. install this google manager first then install follow number 12 credit to rootjunky your S7 will be 100% working... |
