07-23-2016, 15:23 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Location: PAKISTAN
Member: 882981 Status: Offline Sonork: 161363 Thanks Meter: 306 | Sm-g935f s7 edge read cert error BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. (Note, that the cert file for this model is unique. You can write cert, wich is readed from this device exactly.) 7. Press 'Write NV DATA' if you need to restore NV backup. Operation: Read CERT Selected model: SM-G935F Software version: 26.0 Waiting ADB device... OK Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: SM-G935FZDUPAK Phone version: G935FXXU1APEQ PDA version: G935FXXU1APF2 CSC version: G935FOJV1APF1 CSC country code: PAKISTAN CSC sales code: PAK HW version: MP 0.801 Phone S/N: RF8H30F5E0J Modem board: SHANNON335 RF cal date: 20160304 IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Reading data... error (9) Done with Samsung Tool PRO v.26.0 |
