Old 02-10-2018, 05:33   #1 (permalink)
potzilla's Avatar
Member: 168612
Thanks Meter: 11
SM-G935FD stuck on setup connection....error? [S: Answered]
action take:
i have already update driver from 1.4 to 1.5.45 and the latest 1.5.60 but still same problem.
i have already try flashing on ODIN 3.12.3 still gives same error. stuck on setup connection
i also try remove the battery change usb port on unit still the same.
I also try on my Z3X pro 30.7 but still no luck
please help anyone who encounter such problem.
Checking local file... OK
Searching server... OK
Compare local and server file... OK (up to date)
Searching USB Flash interface... COM19 detected
Setup connection... error
Done with Samsung Tool PRO v.30.7
Old 02-11-2018, 22:15   #2 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 178,076
Originally Posted by potzilla View Post
action take:
did you try other cable?pc?
firmware?
Old 02-12-2018, 09:14   #3 (permalink)
Member: 701404
Thanks Meter: 15
replace charging base....
Old 02-12-2018, 09:37   #4 (permalink)
Asad ali khan's Avatar
Member: 2454192
Sonork: 100.1674433
Thanks Meter: 663
action take:
first do hard reset then wait for phone fully bootup then again put in download mode and try to flash
Old 02-14-2018, 01:51   #5 (permalink)
potzilla's Avatar
Member: 168612
Thanks Meter: 11
firmware?
yes sir i try 3 other cable including its original package also firmware, i also change the usb port still the same. thank you for the reply.
Old 02-14-2018, 01:54   #6 (permalink)
potzilla's Avatar
Member: 168612
Thanks Meter: 11
it wont go to hard reset sir only on download mode.
Old 02-14-2018, 03:07   #7 (permalink)
potzilla's Avatar
Member: 168612
Thanks Meter: 11
my phone is stuck on this state.
http://s184.photobucket.com/user/udf...22550.jpg.html
Old 02-14-2018, 06:48   #8 (permalink)
Member: 2596108
Thanks Meter: 57
try a different PC as setup connection error is alot of times the computer
Old 02-14-2018, 16:56   #9 (permalink)
potzilla's Avatar
Member: 168612
Thanks Meter: 11
i have try 3 different computer windows xp, windows 7 and windows 8.
but when i try other samsung s7 edge it work ok except for this one. thank you for your reply.
Old 02-14-2018, 18:14   #10 (permalink)
Member: 2802156
Thanks Meter: 173
Your charge port might be bad, do you get the message: Moisture detected in charging port ?
Old 11-12-2018, 10:04   #11 (permalink)
Member: 2048880
Thanks Meter: 55
Try whit latest odin slove your problem
Old 03-10-2019, 22:01   #12 (permalink)
Member: 2736087
i have this problem too
solution???????
Old 03-11-2019, 01:27   #13 (permalink)
xerraco's Avatar
Member: 890926
Thanks Meter: 1,646
solution???????
Well post log, screenshots.
Br,
xerraco
Page generated in 0.36063 seconds with 7 queries
