05-29-2017, 13:53 | #2 (permalink) | |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
In order for you to receive help, it would be necessary for you to tell which firmware version and which binary file you have on your phone: G935W8VLU2BQB6 7.0 Binary: 2 G935W8VLU2APK3 6.0.1 Binary: 2 G935W8VLU1APD3 6.0.1 Binary: 1 That said, you could look for the right combination file. Example: Samsung COMBINATION Letter Codes To Check COMBINATION Compatibility COMBINATION Build Number Released ______________________________________________ COMBINATION_OXA_FA60_J710FXXU1AQB3 ____________________________________________ OXA = CSC build __________________________________________________ __________ FA70 = Android 7 Nougat FA60 = Android 6 Marshmallow FA51 = Android 5.1 Lollipop FA50 = Android 5.0 Lollipop FA44 = Android 4.4 KitKat FA43 = Android 4.3 Jelly Bean FAJP = Android Jelly Bean FTMA = Tizen OS __________________________________________________ _________ O = 2015 P = 2016 Q = 2017 __________________________________________________ ________ A = January B = February C = March D = April E = May F = June G = July H = August I = September J = October K = November L = December __________________________________________________ _______ 1 = Revision 1 2 = Revision 2 3 = Revision 3 4 = Revision 4 5 = Revision 5 6 = Revision 6 7 = Revision 7 8 = Revision 8 9 = Revision 9 A = Revision 10 B = Revision 11 C = Revision 12 D = Revision 13 E = Revision 14 F = Revision 15 ________________________________________________ ______ COMBINATION_OXA_FA60_J710FXXU1AQB3 = 2017 - February- Revision 3 | |
The Following 5 Users Say Thank You to gcceleghg For This Useful Post: |
05-29-2017, 13:59 | #4 (permalink) | |
No Life Poster Join Date: Aug 2012 Location: Bali-Indonesia
Member: 1800628 Status: Offline Thanks Meter: 940 | Quote:
im try downgrade to 6.01 but always failed. on support area comb file G935W8 not available | |
05-29-2017, 14:08 | #5 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | If you are in version 7.0 I recommend degrade to 6.0.1 with binary firmware version: 2 Try to degrade with Odin 3.12.5 or with Odin 3.12.3 Patched Once you can degrade you can use this combination file: COMBINATION_FA60_G935W8VLU2API1_CL7964511_QB108387 66_REV00_user_mid_noship.tar.rar |
The Following User Says Thank You to gcceleghg For This Useful Post: |
05-29-2017, 14:12 | #6 (permalink) | |
and COMBINATION_FA60_G935W8VLU2API1_CL7964511_QB108387 66_REV00_user_mid_noship.tar.rar[/QUOTE] | |
05-29-2017, 14:16 | #7 (permalink) | |
Do not be a problem for that, I'll be able to pass it once you can degrade. I just have to upload it to 4share. | |
05-29-2017, 14:17 | #8 (permalink) |
Member: 1800628 Status: Offline Thanks Meter: 940 | Do not be a problem for that, I'll be able to pass it once you can degrade. I just have to upload it to 4share.[/QUOTE] im waiting sir,..realy i need it |
05-29-2017, 14:26 | #9 (permalink) | |
Yes sir, there is no problem for that. Just wait until you finish uploading 4share. You have been able to degrade? | |
05-29-2017, 15:25 | #10 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Yes sir, there is no problem for that. Just wait until you finish uploading 4share. You have been able to degrade?[/QUOTE] Dear user! If you have been able to degrade to version 6.0.1 binary file: 2 you can use it's combination file to enable adb communication. COMBINATION_FA60_G935W8VLU2API1_CL7964511_QB108387 66_REV00_user_mid_noship.tar.rar (Pass into the .rar) Only you must connect the phone to Z3X after flashing the combination file in normal mode and doing FRP. Then delete the phone from the menu Then flash with stock firmware. |
05-29-2017, 16:12 | #11 (permalink) |
Freak Poster Join Date: Aug 2014 Location: Dominican Republic
Member: 2235918 Status: Offline Thanks Meter: 127 | Dear "gcceleghg": Thank you very much for this helpful explanation which I was looking for a long time. It's possible I'm a really very bad searcher but, thank to you finally I got it. I hope, the user fix his cell issues. Br |
05-29-2017, 18:25 | #13 (permalink) | |
Junior Member Join Date: Jan 2017
Member: 2674189 Status: Offline Thanks Meter: 0 | Quote:
I am maybe crazy but what is the password ? I am not seing anything. Regards, | |
