08-13-2017, 23:13 | #1 (permalink) |
Insane Poster Join Date: May 2016
Member: 2573221 Status: Offline Thanks Meter: 11 | SM-G950F FRP Baypass Done 2 - Using Odin3_v3.12.7 3 - When The Phone Start check if dubug Mode is active 4 - Turn Off The Phone 5 - Put the Phone in Download Mode And Flash it using odin with this Firmware G950FXXU1AQG5_G950FOXM1AQG5_ROM 6 - Congratulation |
08-20-2017, 09:59 | #2 (permalink) |
Freak Poster Join Date: Nov 2007 Location: Pakistan
Member: 628369 Status: Offline Sonork: 100.1609794 Thanks Meter: 48 | I have done it another way, very simple steps. 1. Flash with combination from z3x support COMBINATION_FA70_G950FXXU1AQD1.zip 2. Now flash with this firmware G950FXXU1AQC9_G950FOXM1AQC9_BTU.zip without CSC and from PDA untick Userdata and meta-data/fota.zip. Remember to remove CSC file, to remove tick cross on right side. Now flash with above files. After flash Phone will not ask for gmail account, complete setup. 3. Go to settings/Developer options. Enable oem unlock and factory reset phone from settings menu. after factory reset frp should be completely removed. 4. Finally flash phone with full firmware and select CSC file not Home CSC. 5. Enjoy Flashing log is here in next post. |
The Following 3 Users Say Thank You to kashif_malik For This Useful Post: |
08-20-2017, 10:00 | #3 (permalink) |
Member: 628369 Status: Offline Sonork: 100.1609794 Thanks Meter: 48 | Operation: Flash Selected model: SM-G950F Software version: 29.1 File analysis... OK Total file size: 0x7CCA2DBC (1996 Mb) Searching USB Flash interface... COM438 detected Setup connection... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending param.bin... OK Sending up_param.bin... OK Sending cm.bin... OK Sending nad_fw.bin... OK Sending nad_refer.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending userdata.img... OK Sending modem.bin... OK Sending modem_debug.bin... OK Flashing done (time - 00:02:21) Operation: Flash Selected model: SM-G950F Software version: 29.1 Searching phone and switching to flash mode... OK Operation: Flash Selected model: SM-G950F Software version: 29.1 File analysis... OK Total file size: 0xE4DD1AF0 (3661 Mb) Searching USB Flash interface... COM438 detected Setup connection... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending param.bin... OK Sending up_param.bin... OK Sending cm.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending modem.bin... OK Sending modem_debug.bin... OK Flashing done (time - 00:04:30) Operation: Flash Selected model: SM-G950F Software version: 29.1 File analysis... OK Total file size: 0x15A3F22B5 (5539 Mb) Searching USB Flash interface... COM438 detected Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending param.bin... OK Sending up_param.bin... OK Sending cm.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending userdata.img... OK Sending modem.bin... OK Sending modem_debug.bin... OK Sending cache.img... OK Sending omr.img... OK Flashing done (time - 00:06:41) |
The Following User Says Thank You to kashif_malik For This Useful Post: |
08-20-2017, 10:17 | #4 (permalink) |
Freak Poster Join Date: Jun 2016 Location: Home Age: 27
Member: 2583091 Status: Offline Thanks Meter: 413 | Guys the trick is not what firmware you use, just make sure after flash combination don't flash the "Userdata,meta_data" of the stock firmware because of the combination file userdata image the phone treats it as if you have completed the setup wizard. Sent from my Y635-L21 using Tapatalk |
11-08-2017, 12:13 | #5 (permalink) | |||
No Life Poster Join Date: May 2014 Location: D.I.Khan [KPK] Age: 34
Member: 2192499 Status: Offline Sonork: Stopped using.. Thanks Meter: 1,763 | Quote:
Even no need to take 1 package file you can use BL & AP from any firmware just remove the userdata & metadata and the rest you are done !! | |||
The Following 3 Users Say Thank You to EjazATF For This Useful Post: |
07-18-2018, 11:41 | #6 (permalink) |
No Life Poster Join Date: May 2003 Location: POLAND
Member: 27761 Status: Offline Thanks Meter: 55 | guys i have G950F with firmware: XEO-G950FXXU2CRF7-20180626180420 AP_G950FXXU2CRF7_CL13760092_QB18535731_REV00_user_ low_ship_meta.tar.md5 and i need correct combo file FA70 for device 2 (u2) i can't write via odin any of those files: COMBINATION_FA70_G950FDXU1AQD1 because i'm getting error: SW REV check fail (bootloader) device: 2, binary 1 this mean i need another combo file, somebody could help? |
08-13-2018, 19:43 | #7 (permalink) |
Junior Member Join Date: Sep 2008
Member: 865955 Status: Offline Thanks Meter: 0 | Frp Samsung S8 Mew security Good afternoon I need help removing google account new protections as you can see in the image "B: 3 K: 2 K.2", combinations that are available in ZX3 do not work |
