06-13-2018, 05:38 | #1 (permalink) |
No Life Poster Join Date: Jun 2008 Location: World
Member: 792851 Status: Offline Thanks Meter: 136 | samsung g570y trying to read online code give servicer error? i have try g570y ,g570m,g570f all have same error what to do? Code: UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. Reading codes using sever: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone using sever. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. Operation: Read Codes via Server Selected model: SM-G570F Software version: 32.7 Checking Login and Password... OK Ballance: 10 crd. You have 10 credit(s) left. This operation takes 5 credits.Continue? Yes Searching Samsung modem... detected COM63 Reading phone info... Model: SM-G570Y AP version: G570YDXU1BQJ1 CSC version: G570YVFJ1BQJ1 CP version: G570YDXU1BQJ1 Product code: VFJ Phone SN: R58JA4XYGWR IMEI: 355078080735597 Unique number: CQ3009160D24294 Incorrect model selected. This may damage your phone. Continue? Yes Searching Samsung diag port... detected COM62 Reading phone info... OK CP version: G570YDXU1BQJ1 CP build: Oct 11 2017 17:58:45 Reading data from phone... OK Calculating... OK Searching server... error unknown error Done with Samsung Tool PRO v.32.7 |
06-13-2018, 21:04 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,557 | Quote:
