Old 10-02-2018, 12:25   #1 (permalink)
Member: 1549859
Thanks Meter: 13
SM-G950u codes not accept [Solved]
hello I have g950u
read codes using service codes recieved but when entering 'incorect unlock code entered'
Checking Login and Password... OK
Ballance: 50 crd.
You have 50 credit(s) left. This operation takes 5 credits.Continue? Yes
Waiting ADB device... OK
Reading phone info...
Model: SM-G950U
Android version: 8.0.0
PDA version: G950USQS5CRH1
CSC version: G950UOYN5CRH1
Phone version: G950USQU5CRF1
Product code: SM-G950UZSAATT
CSC country code: USA
CSC sales code: ATT
Phone SN: R38J80N4F6V
IMEI: 357723081631067
HW version: REV1.0
RF cal date: 2017.08.23
Chip name: MSM8998
Modem board: MSM8998
Security patch: 2018-08-01
Boot Warranty bit: 0
Waiting for device to become ready... OK
Initialization zTool... OK
Running zTool, please wait...
Start... OK
Initialization... OK
Generate and check client proof... OK
Verify proof by client... OK
Reading data from phone... OK
Searching Ramdump interface... COM18 detected
Calculating... OK
Searching server... OK
Waiting for server answer... OK
Freeze code: 63695972
NET lock: 41582716
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
For check lock status: *#7465625#
Done with Samsung Tool PRO v.33.8
please check video too
https://y outu.be/XdjP2xd5UzI
I want back credits and if z3x has solution for this
Old 10-02-2018, 13:23   #2 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 1,098
If you use search button magic you will find that you should flash latest stock modem or full rom and codes will work
The Following User Says Thank You to souma_k For This Useful Post:
Old 10-02-2018, 18:58   #3 (permalink)
Member: 1549859
Thanks Meter: 13
File analysis... OK
Total file size: 0x1A2DB5F2E (6701 Mb)
Searching USB Flash interface... COM18 detected
Setup connection... OK
Getting device info... OK
Reading PIT from phone... OK
Sending abl.elf.lz4... OK
Sending bksecapp.mbn.lz4... OK
Sending xbl.elf.lz4... OK
Sending tz.mbn.lz4... OK
Sending hyp.mbn.lz4... OK
Sending devcfg.mbn.lz4... OK
Sending pmic.elf.lz4... OK
Sending rpm.mbn.lz4... OK
Sending cmnlib.mbn.lz4... OK
Sending cmnlib64.mbn.lz4... OK
Sending keymaster.mbn.lz4... OK
Sending apdp.mbn.lz4... OK
Sending msadp.mbn.lz4... OK
Sending sec.dat.lz4... OK
Sending NON-HLOS.bin.lz4... OK
Sending storsec.mbn.lz4... OK
Sending boot.img.lz4... OK
Sending recovery.img.lz4... OK
Sending system.img.ext4.lz4... OK
Sending persist.img.ext4.lz4... OK
Sending modem.bin.lz4... OK
Sending adspso.bin.lz4... OK
Sending cache.img.ext4.lz4... OK
Sending userdata.img.ext4.lz4... OK
Flashing done (time - 00:08:50)
flashed latest G950USQS5CRH1
but magic still same
Old 10-02-2018, 19:15   #4 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 1,098
Originally Posted by froyd777 View Post
File analysis... OK
Do a factory reset and then retry
Old 10-03-2018, 15:01   #5 (permalink)
Member: 1549859
Thanks Meter: 13
flashed after flash reset and codes worked
problem solved thank you
The Following User Says Thank You to froyd777 For This Useful Post:
Old 10-11-2018, 14:58   #6 (permalink)
Member: 747069
Thanks Meter: 2
share the firmware
many thanks
Old 10-11-2018, 16:36   #7 (permalink)
Member: 747069
Thanks Meter: 2
G950USQS5CRH1 I need a modem so I can not
Old 10-11-2018, 16:48   #8 (permalink)
Member: 2613252
Thanks Meter: 578
Hello, depends on which modem are you looking for for g950u binary 5?
If you need a eng modem for g950u binary 5 to unlock this link that I posted you can download.
ENG MODEM G950U BINARY 5
G950U_G950U1_G950W_EngModem_BIT5
Page generated in 0.26827 seconds with 7 queries
