SM-G950U unlock UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will appear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Unlocking TMB using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock TMB via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Unlocking SPR using sever: 1. Insert not SPR card to the phone and power it on. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock...' button, select 'Unlock SPR via Server', write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-G950U Software version: 38.7 Checking Login and Password... OK Ballance: 20 crd. You have 20 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G950U Android version: 9 PDA version: G950USQS6DSJ1 CSC version: G950UOYN6DSJ1 Phone version: G950USQS6DSJ1 Product code: SM-G950UZKACHA CSC country code: USA CSC sales code: CHA Phone SN: RF8M40D988A IMEI: 357506094211302 HW version: REV1.0 RF cal date: 2019.04.03 Chip name: MSM8998 Modem board: MSM8998 Security patch: 2019-10-01 Boot Warranty bit: 0 SIM State: NETWORK_LOCKED Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching Samsung diag port... detected COM258 Reading phone info... OK Reading data from phone... OK Searching Ramdump interface... COM17 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 49605250 NET lock: 25315204 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.38.7 Sir this phone as you see the above info its unlocked but its saying SIM card changed Restart your phone to start using your new SIM card To make an emergency cal before restarting, tap Emergency call :confused::confused::confused::confused::confused: :confused: |
Thats normal ... so what happens after it restarts ? |
Have you try to flash it ? |
