Old 12-03-2019, 13:56   #1 (permalink)
Member: 2294589
Thanks Meter: 39
SM-G950U unlock
UNLOCK INSTRUCTIONS:
Unlocking with original MSL code:
Warning! Knox warranty must be active (0x00)!
If you have it voided (0x01(void)), then you can't unlock this phone with MSL.
1. Phone must be powered on.
2. Type *#0808# and select 'DM+ACM+ADB'.
3. Run dialer and type *#0*# (service mode will appear).
4. Connect the phone to USB cable, choose correct COM port in port settings.
5. Press 'Unlock' button.
6. Paste MSL code in new opened window and press 'OK'.
Unlocking TMB using sever:
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information'
to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock TMB via server' button, write your login and password in window if it will appear.
(Login and password will be saved as default after first input and can be changed in settings.)
Unlocking SPR using sever:
1. Insert not SPR card to the phone and power it on.
5. Press 'Unlock...' button, select 'Unlock SPR via Server',
Reading codes using sever:
5. Press 'Read Codes via server' button, write your login and password in window if it will appear.
Operation: Read Codes via Server
Selected model: SM-G950U
Software version: 38.7
Checking Login and Password... OK
Ballance: 20 crd.
You have 20 credit(s) left. This operation takes 5 credits.Continue? Yes
Waiting ADB device... OK
Reading phone info...
Model: SM-G950U
Android version: 9
PDA version: G950USQS6DSJ1
CSC version: G950UOYN6DSJ1
Phone version: G950USQS6DSJ1
Product code: SM-G950UZKACHA
CSC country code: USA
CSC sales code: CHA
Phone SN: RF8M40D988A
IMEI: 357506094211302
HW version: REV1.0
RF cal date: 2019.04.03
Chip name: MSM8998
Modem board: MSM8998
Security patch: 2019-10-01
Boot Warranty bit: 0
SIM State: NETWORK_LOCKED
Rebooting phone... OK
Waiting for device to become ready... OK
Initialization zTool... OK
Running zTool, please wait... OK
Reading data from phone... OK
Searching Samsung diag port... detected COM258
Reading phone info... OK
Searching Ramdump interface... COM17 detected
Calculating... OK
Searching server... OK
Waiting for server answer... OK
Freeze code: 49605250
NET lock: 25315204
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
For check lock status: *#7465625#
Done with Samsung Tool PRO v.38.7
Sir this phone as you see the above info its unlocked but its saying
SIM card changed
Restart your phone to start using your new SIM card
To make an emergency cal before restarting, tap
Emergency call
Old 12-03-2019, 16:44   #2 (permalink)
Member: 399404
Thanks Meter: 38
Thats normal ... so what happens after it restarts ?
Old 12-03-2019, 18:11   #3 (permalink)
Member: 2294589
Thanks Meter: 39
When you restart it tells you again to restart it
Old 12-04-2019, 01:21   #4 (permalink)
Member: 399404
Thanks Meter: 38
Have you try to flash it ?
Page generated in 0.20256 seconds with 7 queries
