12-02-2018, 12:34 | #3 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,551 | Quote:
12-02-2018, 16:32 | #4 (permalink) |
Junior Member Join Date: Dec 2006
Member: 413949 Status: Offline Thanks Meter: 2 | UNLOCK INSTRUCTIONS: Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Unlock Selected model: SM-G960U Software version: 34.3 Checking Login and Password... OK Ballance: 22 crd. You have 22 credit(s) left. This operation takes 8 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G960U Android version: 8.0.0 PDA version: G960USQU1ARB7 CSC version: G960UOYN1ARB7 Phone version: G960USQU1ARB7 Product code: SM-G960UZPASPR CSC country code: USA CSC sales code: SPR Phone SN: R58K23W165Z IMEI: 356417090436581 HW version: REV1.1 RF cal date: 2018.02.23 Chip name: SDM845 Modem board: SDM845 Security patch: 2018-02-01 Boot Warranty bit: 0 SIM State: CARD_IO_ERROR Searching Samsung diag port... detected COM216 Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Checking data... OK Searching server... OK Waiting for server answer... Incorrect size of server answer Done with Samsung Tool PRO v.34.3 |
